SC300 need a flasher relay
Ladies and gents, my 1993 SC300 manual has had the flasher relay go bad. The Lexus part number is 81980-24020, but it's been discontinued, and I can't find one with that part number anywhere. Does anyone have a relay to sell, or do you have an equivalent part number in Toyota or any other brand? Ebay and internet searches have led to conflicting results. Any help would be appreciated.
Fred
fredmahan@hotmail.com
Fred
EP35 flasher should fit just about any auto parts store will have them. Or if you're picky and need OEM salvage yard.
I bought both an EP35 and EFL9 just to test with as future replacements and neither are suitable.
1995-2000 SC’s may be able to use either aftermarket flasher relay but not earlier SC’s.
In another thread I’ve started researching the possibility of how feasible it is to rebuild a factory 81980-24020 flasher relay. I’m advising people hold onto theirs even if the unit is blown in case it becomes possible to replace some of the affected internal parts.
It will take some experimenting and physical inspection of the OEM relay first. I’ve thrown the idea at O.L.T. and I may try contacting Yamae (former Toyota ECU and electronics engineer) about it as well if he is still active on the forums.
Unlike late-1994 and 1995-2000 SC’s there is no other vehicle Toyota or Lexus produced which cross references to this specific relay part number.
https://www.clublexus.com/forums/sc-...nal-relay.html
NYCsc300 (12-09-20)
geerb --
Thanks for the suggestion. Didn't find any sources on line, but found the relays in cars at a local "pull" place. It sure is hard to get to, especially in a dead car where you can't move the seat back, and the carpet is all wet!
Fred
Fred
You might want to contact Tanin and see if they can repair one of your defective units.... Nothing to lose to ask...
Duck05, thanks for the suggestion. I just sent them an e-mail.
Fredmahan@hotmail.com
https://www.clublexus.com/forums/per...0-24020-a.html
I live in the Los Angeles county area. There are no other 81980-24020’s at any of the dealerships or junkyards that I’ve contacted.
I’ve been looking at other aftermarket 5 pin flasher relays.
I’ve got two (different ones) on order vía Amazon. I hope to use the on line Sc300 diagrams to extrapolate where to manually connect the flasher pins to the factory flasher receptacle- hopefully, I won’t fry anything too bad.
There is quite a bit of documentation amassed already but now at current time we're fast approaching the need to fully understand how a professional electrical engineer designs a compact twin-relay chip controlled flasher relay unit (accounting for all electrical values necessary) to go further with any custom solution.
The OEM 5-pin relay we have has totally custom function assignments, is timed by a few specific capacitors, resistors and transistors and has a 6-pin digital controller chip assigning functions to not one but TWO relay mechanisms inside the OEM 81980-24020 unit. It was designed this way in order to spread the electrical load over the two internal relays (one relay for each side of flashers) for better long term durability of the components and electrical contacts.
^^ That is what makes this a difficult problem to find solutions to. It is not a conventional flasher relay at all.
The 1995-2000 SC's and Soarers used a more conventional and easier-for-aftermarket flasher relay and flasher circuit design.
It's slow going to figure out a way to make an aftermarket equivalent relay. At the moment the first most promising bet is to identify all the replaceable capacitors, resistors, etc. that can be sourced from Digi-Key or Mouser in the *exact* type originally used by Toyota, desolder the old ones and replace with brand new ones and see if that alone can fix a bad relay.
These do show up on eBay from time to time (maybe just not at this moment though). I highly recommend you KEEP any 81980-24020 relay even if you've confirmed that it is bad because if/when we do discover a way to repair or rebuild one of these very specific Toyota relay units it will come in handy for owners to have their original relay assemblies to get repaired.
No other Toyota or Lexus model used this part other than the 1991-1994 Soarer Z30.... which has the same exact relay unit only with the part number 81980-24010 and perhaps a *very* minor electrical difference accounting for the digital instrument clusters in those cars (or maybe they are exactly the same relay electrically but just using a different part number). Just the same with those early Soarers there is no aftermarket equivalent for their OEM relay and those are discontinued as well.
We have to figure out a rebuild or custom solution (that 100% works reliably) ourselves within the community going forward. Keep the bad relay that you have for future repair work even when you do find a working good used one to replace it with.
If someone sends me an original I'll clone it.
KahnBB6 (09-03-20)
If you're capable of that kind of ground up electrical engineering then such a thing can be arranged.
Have you already read through the current 81980-24020 dissection thread to get an idea of where we're at with knowledge and electrical schematic info so far?
I have looked into it as much as I am capable of and Yamae and O.L.T. have provided some very valuable insight and even a bit of reason from older Toyota electrical engineers as to why it was designed this way in the first place in the very late 1980's but beyond identifying and sourcing any available replaceable small internal components (to desolder and replace with new caps, resistors, etc) that aren't proprietary Nippon-Denso I can't go much further with the project myself. I am not a professional electrical engineer capable of redesigning an entire part like this from scratch with all new components and a brand new custom printed circuit board.
If you can take this further than we've been able to so far then I know I and others with 1992-1994's are interested.
Why Lexus did this is baffling to me. My thinking is it should be possible to modify a single relay flasher, or simply combine two flasher relays to do the same job as the original.
edit - forgot to say, this proves Lexus tried to fix a problem that wasn't there, how often does a Toyota/Lexus flasher relay go bad? The answer is rarely, but in this case the dual relay flasher goes bad! This is the overly engineered stuff I expect from a company like BMW or VW not Lexus.
KahnBB6 (09-06-20)
I have many, many years electrical/electronic experience. Can't promise anything of course, but in my view this is simply two flasher circuits in one box. It is an over complex design to say the least, and an answer to a problem that didn't exist. The single relay Toyota flasher is very robust and the relay contacts can easily handle the current required. It's not like the SC had way more lights/much higher load than any other car.
I have.
I have.
Anyway, perhaps we should switch further discussion to the flasher unit dissection thread.
And I'll PM you about this shortly as to what you'll need beyond just a flasher unit if you do want to take it on. It is understood that there are no guarantees but it sounds like you can take this farther than I'll be able to. I just hope we can find a good and reliable rebuild or replacement solution of any kind that all 1992-1994 SC and 1991-1994 Soarer owners can benefit from... since these relays are no longer sold new and have no aftermarket equivalent.
