Post your MOD list
Here is the main things.
Fully Race Ported Head
Custom Tubular Turbo Manifold
Custom SP Intake Manifold
Custom 3.5" Turbo Back Exhaust
14mm Diameter Head Stud Conversion
Custom Twin Entry Fuel Rail
160 lbs/hr injectors (roughly 1600+cc)
Twin Walbro 255 LPH In Tank Pumps
Accufab 85mm Throttle Body
Greddy Pistons
Pauter Rods
Custom underground crank with felpro bearings
Supra TT 6 Speed LSD Rear End
Custom Driveshaft
SP400 3 speed manual valve body transmission upgrade
Griner Racing Trans brake
Speed Pro/FAST Engine Management
Custom Distributorless Ignition Setup
Unorthodox underdrive pullies
A/C delete
Custom NHRA Certified Chromoly Roll Cage
Greddy 3 Row Front Mount Intercooler
HKS GT 60mm Wastegate
SP88 Turbo
Custom Direct port dry 200 shot nitrous setup
Supra TT brake upgrade (front and rear)
Volk Millenium Edition TE37s
CCW Skinnies for the front
Supra NA Wheels With ET Streets
DEFI Boost, EGT, Fuel Pressure, and Tach (Stack coming in next week!)
Crower 272 Cams
Custom Crank Trigger
Trunk Battery Relocation
Master Power Cutoff Outside Car
Greddy Type-R BOV
Custom IC Pipes
Rear Seat modified to work with cage
Line Lock
NX Billet Nitrous Bottle Brackets
AEM Cam Gears
-6 AN Fuel Lines
-6 AN Fittings (Fuel, Oil, etc.)
TT Valve Covers (Custom Powder Coated)
TT Spark Plug Cover
Custom Relocation of Power Steering Resevoir
MSD DIS-4
Powerhouse Solid Motor Mounts
Greddy Pistons
Pauter Rods
Custom Driveshaft
A/C delete
SP88 Turbo
Crower 272 Cams
Greddy Type-R BOV
Custom IC Pipes
Line Lock
AEM Cam Gears
-6 AN Fuel Lines
TT Spark Plug Cover
MSD DIS-4
proxes FZ4 225/50/16
infinities rear
D-speed clears with LED bulbs
Sylvania silverstars (in the mail)
Piaa parking light bulbs(in the mail)
body:scrapes and dents under door (taking it in Monday)
dented low front fender (taking it in Monday)
scrapes on front lip (taking it Monday)
rear bumber craked(hit and run, taking it in Monday)
the above are delaying my future mods(some sort of descent wheels, fog light conv., 97~skirts, and maybe rust resistant coilovers)
I have as many destructive mods as constructive... maybe I don't belong here
infinities rear
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Chicago Lexus Club Moderator
Greddy Pistons
Pauter Rods
Custom Driveshaft
A/C delete
SP88 Turbo
Crower 272 Cams
Greddy Type-R BOV
Custom IC Pipes
Line Lock
AEM Cam Gears
-6 AN Fuel Lines
TT Spark Plug Cover
MSD DIS-4
Greddy Pistons
Pauter Rods
Custom Driveshaft
A/C delete
SP88 Turbo
Crower 272 Cams
Greddy Type-R BOV
Custom IC Pipes
Line Lock
AEM Cam Gears
-6 AN Fuel Lines
TT Spark Plug Cover
MSD DIS-4
Chris
Originally posted by DIrEctQL
TT spark plug cover fits the GE block? Sweet. Maybe when the engine swap is complete I'll keep the cover with lex logo. Unless it's different from what I am thinking.
Chris
Chris
it does if you have tt valve covers.
![](http://www.mvpmotorsports.com/Merchant/ati_mk4.jpg)
So I can't take my stock Lexus GE spark plug cover and put it on the GTE motor? I might get the one MVP Motor Sports has for sale:
-Ethan
Not unless you put the GE valve covers on too.
-Ethan
-Ethan
Chris
Here's my short but sweet list.
Injen Intake
Custom Exhaust with WR mufflers
19" Racing Hart M5's with Michelin Pilot Sport rubber. Possibly do some iforged next year.
WR ECU upgrade
Poineer DVD HU. Rest of the system next year.
D-speed clear corners.
CD/slotted rotors
SS brake lines
Painting on engine and calipers.
Almost a set of Do Luck bumpers. Read my post in the Lobby for that one.
Injen Intake
WR ECU upgrade
CD/slotted rotors
SS brake lines
Ethan Banks makes us all look like rookies, I shouldn't even bother posting ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Engine / Performance
Sound Performance SP-63 Turbo A/R .83
GReddy 3 Row Front Mount IC
Sound Performance Jet-Hotted Header
HKS GT Racing WasteGate
Blitz Blow Off Valve
IC Piping All Custom 3" Powdercoated Silver
GREX (GReddy/Trust) 2.0mm Metal HG
ARP Stud Kit (torque to 75lbs.)
HorsePowerFreaks Clutch Sprung w/ ACT PP
Fuel Delivery
6x 72lb. Bosche Style Low Impedance Injectors
2x Walbro GSS341 Fuel Pumps in tank
Sound Performance Ported 2JZ-GE Fuel Rail
Aeromotive Racing FPR
Exhaust System
Sound Performance 3" Ceramic Coated DP
Custom Designed 3" Single Exit Exhaust w/ 4" Tip
Bullet 3" Muffler Straight Through Style
Factory Toyota Supra Twin Turbo Midpipe
Electronics
AEM Standalone Engine Management System
TechEdge v1.0 WideBand O2 kit w/ Display
Phantom 30-0-30 PSI White Faced Boost Guage
GReddy White Faced EGT Guage w/ Memory
3x Factory DSM Resistor Packs
Suspension / Wheels / Brakes
17" x 7" ADR Concept Pros
225-45-ZR17 Toyo Proxes
Eibach Sportline Springs for Supra Twin Turbo
Factory Supra Twin Turbo Shocks
iRotors Drilled/Slotted F/R Rotors
Axxis Metal Master F/R Pads
Audio / Multimedia
2x 15" Phoenix Gold XMax Subs
Orion HCCA 150R Amplifier
Lanzar VibeX6 3-way Crossover
Fuel Delivery
Exhaust System
Electronics
Audio / Multimedia
Here are my (modest by comparison) upgrades:
-Injen Intake
-Eibach Prokit Springs
-Tokico Shocks
-Borla Exhaust
MRVF353 Alpine 30x4 & 100x1 V12 AMP
4.5 Boston Acustics Pro Series 4 1/2" & 1"
6.5 Boston Acustics Pro Series 6 1/2" & 1"
EREG180 Alpine 11 Band Eq with BBE
10IB4 JL 10" 8 OHM Freeair Woofer
-Injen Intake
-Tokico Shocks
-Borla Exhaust
