What is this hole?
What is this hole?
While going over my engine bay, I saw a hole towards the front of the engine. I have no idea what it is. It appears to be some form of tank.
Any ideas?
Any ideas?
Looks like a radiator coolant overflow that is missing the cap.
NYCsc300 (03-23-21)
Ahh, thank you. I'll check for a radiator overflow cap.
It is a '99 400 with the 1UZ VVTI engine.
I've never seen a reservoir that looks like that. Early SC400s had it over by the PS reservoir, square shaped, and later ones moved it into the bumper space like SC300s. That one looks like a modification. I can't quite make out the markings, but it looks OEM, from a different application.
Ali SC3 (03-18-21)
Ahh! I had the hydraulic fan replaced with two electric fans. That makes sense, then. Thank you!
Just came back from putting in an airbag during my lunch break. (I'm working at home.) Nice to have a GS steering wheel with a functional airbag.
original wheel
gs430 wheel
original wheel
gs430 wheel
Guessing you swapped in the electric fans from an IS300 or similar with the built in reservoir on top. You can use that reservoir instead of the bumper mounted one if you like.
You would just have to reroute the overflow hose from the radiator to that one, fill it, and grab a cap from an IS300 and you should be good to go.
scsexy (03-18-21)
