Tips for a 2k mile road trip in the SC400
Hi CL
Soon I'll be traveling a little over 2k miles on a road trip roughly within a span of 1-3 days. I'm sure we all know that the UZ would be able to handle it with no issues.
Has anyone been in a similar scenario (1k mi.+ trip)? Where there any problems that you came across regarding the vehicle itself?
My biggest fear is something happening in the middle of nowhere. I will try to make a checklist of small maintenance I might need to do to prevent any sort of breakdowns. I plan on hauling a small uhaul trailer but I don't think it will be too much of an issue. I'm still researching on that part of how to adequately tow.
Ill keep this thread updated as I close in to my departure date.
I've daily driven mine for over 1k miles so far... Its not the same, I know, but I've packed, a 5qt jug of oil, 1 full gal of coolant mix and water, a bag of rags, a small tool box with a compact impact wrench, tire patch kit, a couple hoses, fuses, pliers and a roll of 0 gauge wire just in case I need to jump something, this was more recent as my previous experiment failed....
The following 2 users liked this post by Tallyhoe:
joewitafro (05-01-21),
Slackful (04-30-21)
The following 2 users liked this post by SC400slide:
Sc400dunit (05-06-21),
Slackful (04-30-21)
Make sure you have a working jack, full sized spare tire, extra fuses, electrical tape. I would carry 2 gal distilled water and a gallon of premix among the things listed above. I've towed more than a few times with my gs300, just need a trailer mount; wiring hooked up. Be easy on it, have proper tongue weight, and only pull a max of about 1500 lbs.
I would seriously consider leaving the full-size spare at home, using that space for tools and coolant, and bringing along a 4-pack of fix-a-flat. The odds of any mechanical or electrical failures are low enough with a well-maintained SC, I'd be more concerned about multiple flats leaving you stranded on that long of a trip.
Is the trailer absolutely necessary, or can you squeeze stuff into the car and do without it? You'll find the trip much more pleasant without ... and less stressful not having to watch so closely for overheating.
perfctreig (05-04-21)
As far as the weight of my load that will potentially go on the trailer is less than 250 lbs. The wheels will probably be the heaviest of the items I will be bringing. Below is something I had in mind of renting from uhaul.
The weight won't be an issue. I'm referring to towing a trailer for that long of a distance, behind a vehicle not designed for towing. It won't be an enjoyable drive. Backing up sucks. Visibility sucks. High winds may catch you by surprise.
If a spare set of wheels are the only thing necessitating the trailer, I would absolutely look to sell them pre-move. You can always buy another set later. Or, perhaps look into a temporary roof rack for them. The weight up top would be negligible.
KahnBB6 (05-02-21)
Yeah, my son drove his '95 400 from Los Angeles to Seattle and back last year. That was almost 2400 miles. Not a problem. Of course, he did NOT have a trailer. I'd highly recommend renting a truck for that.
The following 2 users liked this post by perfctreig:
Slackful (05-04-21)
Another thought: If you were planning on a trailer, you were going to be adding a hitch. So, continue down that path but use one of those hitch cargo racks instead of a trailer. That would easily handle the size and weight of a set of wheels, and shouldn't be too tough to devise a way to strap down so they don't roll on down the road behind you... A cable lock or chain through them, and a tarp over them (plus a locking hitch pin), should keep them from wandering off at rest stops.
That'll be cheaper than a trailer rental and should be a much more pleasant drive.
Slackful (05-05-21)
4 tires and wheels hanging on the trunk of your car is more tongue weight than you would have pulling that trailer. As someone who has towed with my lexus hundreds of miles with loads between 400 and 1500 lbs. i would not even blink twice thinking about towing that little trailer with four wheels laying down and whatever misc stuff packages in and around it. Just make sure you have about 50lbs of tongue weight, and balance the rest of the weight above the trailer axle. Its simple.
However, tongue weight of a cargo rack relative to that of a trailer is irrelevant. All that matters is the tongue weight is within the car and hitch's capabilities. If the 200 lb estimate is correct, that's ~2000 lb trailer weight equivalent, which I'm guessing is okay. Without checking, I would assume the SC hitches are 3000 lb rated.
A hitch cargo rack will put a load on the car opposed to the way it was designed. Putting, say 200#, perhaps 2' to the rear of the bumper is a suspension leverage wanting to tilt the car considerably more than 50# trailer tongue weight 6" behind the bumper. That will also impact handling much more than if it were on a large SUV or pickup. Pulling the load of a trailer of, say 1,000#, will put more strain on the engine and drive train, but not on the suspension. Each is a different factor towards the car.
2) Where are you coming up with 50 lb tongue weight? You're obviously assuming the wheels have tires -- yet to be confirmed -- based on the 200 lb figure, so only a 300 lb rental trailer to reach 500 lbs total (10% tongue weight estimate)? Even Harbor Freight's dinky little fold-up trailers weigh more than that. I would guess 500-600 lbs minimum for trailer weight, plus whatever goes in it.
Edit: Disregard the OE spare tire. I'm thinking of tossing it entirely. I have the 4th Enkei wheel in the pit at the moment. So three wheels in total on the external platform.
