SC- 1st Gen (1992-2000)
New black emblems = $9.34 pictures!
Old 10-20-03, 07:33 PM
  #31
SC300Es
SC300Es's Avatar
Front
Old 10-20-03, 07:34 PM
  #32
SC300Es
SC300Es's Avatar
Back
  #33
SC300Es
SC300Es's Avatar
Last
Old 10-20-03, 09:26 PM
  #34
claus44
claus44's Avatar
Mind if I copy that?? My gold badges are pretty worn too and I've been thinking about what color to paint mine to until I can have enough spare $$ for a new set of silver badges. Great Job!!
Old 10-20-03, 09:51 PM
  #35
lexus_sc400_n20
lexus_sc400_n20's Avatar
looks nice, i used the same brand paint. It has a little bit of a metallic luster to it in person. How many coats of paint/ clearcoat did you use?
Old 10-20-03, 10:07 PM
  #36
SC300Es
SC300Es's Avatar
Claus, go right ahead. Maybe you'll perfect the whole process.
lexus_sc, I did as many coats as I can over the weekend. The little "SC", I did 2-3 times. I put my finger prints on it so I stripped the paint and did it over. Then the clear coat.
Only problem I had was, originally I put 3M double sided tape on the backs. When I went to mount the emblems they looked too high from the body. I was worried about water and dirt getting under so I went and got 3M emblem glue at Autozone. I smeared a little glue around the "SC" and the "300" Tomorrow, after everything dries I'll go wipe the excess glue around the emblems.
The other thing was my gold emblems had the clear coat layer on them.. It looked like a plastic wrapping on top of the emblems. Make sure you completely remove that layer. Otherwise, when you spray the paint you can see the different layers where the clear coat is still on the emblem and where it's not.
Ed
Old 10-21-03, 04:50 PM
  #37
claus44
claus44's Avatar
Thx for the advise I'll sand the emblems a little and use some rubbing compond before I paint them Might even use some primer if I have extra time
Old 10-21-03, 06:17 PM
  #38
RSTSpeed
RSTSpeed's Avatar
SC300 Es, that gunmetal looks GREAT. I love that. It makes me wish my car was white to do that, too! lol
Old 10-21-03, 06:57 PM
  #39
SC300Es
SC300Es's Avatar
Thanks guys.
Claus, I was able to get rid of the clear coat with my nails and teeth.
I only forgot to do one part. The antenna nut..I think I'll just get a chrome one for that..I'm done painting for a while.
Ed
Old 10-21-03, 07:20 PM
  #40
SC300Es
SC300Es's Avatar
day shot of the finished job..
Old 10-21-03, 10:01 PM
  #41
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
AZNTEAZER needs to do that...
Old 10-22-03, 11:23 AM
  #42
rushgator
rushgator's Avatar
SC300Es, I dig that gun metal grey. Looks good on your white SC.
Old 10-23-03, 09:21 PM
  #43
LexFather
Guest
Posts: n/a
gREAT work people! Looks great!
Old 10-24-03, 07:02 PM
  #44
Lexls400
Lexls400's Avatar
I like the black emblems, I put black pearl on my silver 1990 Ls400... I hate when they put gold emblems on a silver car like mine.
-Joe
Old 10-31-03, 11:16 PM
  #45
claus44
claus44's Avatar
Did it last weekend and I must say it looks really good!! Got several praises from ppl too Here are some tips I would like to share
1. Use 3M Molding Tape to attach your front emblem. If you use glue, it may be very difficult for you to remove the emblem if you unfortunately need to do some touch up/repaint. There are chances that a rock can chip your nice newly painted front emblem.
2. You do not need to remove all the left over foam tape for the badges if you are going to use glue to attach them. Just make sure the left overs are thin. This way, you can minimize the chance of chipping your paint. Also, it should make your life a bit easier if you need to remove them in the future.
3. You should use primer since the Dupli Color gun metal paint is not that sticky. Plus, there might be some small dents on the emblem, so by sanding and useing primer, you can make the surface nice and smooth again.
4. Remember to heat up your badges really well with your hair dryer or heat gun before you try to remove them.
4. This is definitely a worth while job if your gold emblems are fading
Quick Reply: New black emblems = $9.34 pictures!
