I got a factory Pyle alarm that was already installed when I purchased. Got it working great and even connected the trunk pop.
Was looking into installing the window roll up module to roll all windows up after arming the alarm. Watched some Youtube videos on how to do it and it looked pretty straight forward so I order a module from Amazon.
Anyone do this with their windows yet? I would love to know which wires to clip and to connect the module.
Need the 12v constant, ground, ignition and window switch wires to and from the master switch (driver side) and the passenger side wire colors.
THANKS!
Reason: alignment
Why do you need an aftermarket alarm system in your Lexus? The OEM system is already quite descent, having all the functionality you need, one of its features is an ability to raise all the windows by turning the key in a door lock to the "Lock" position for a few seconds.
If you really want to, you can make a simple time delay circuit that will short the switch on the door lock to raise all the windows, but those kinds of retrofits often end up causing a lot more trouble in the future than what they actually save.
I didn't really need the alarm but the old owner had one already installed which in turn disabled the factory keyless remote and I didn't know how to re-enable it.
Does that key initiated window roll up work in 1993s?
Do you have an OEM remote? If so, you will have to program it before you can use it.
^ Test fail. Mine doesn't behave that way with either door lock.
Does it work for anyone else?
Oh well, then it appears that this feature was only introduced with a next generation cars, here is an owners manual for a 2000 ES300 showing the operation I described. There may be a chance to enable it with Techstream software, but I've never tried it..
Sorry for luring you into this idea before checking.
Only one way to find out..
Hope this helps and best of luck!
I do have the OEM remote and tried to hold the key in the lock position but no window movement. I read that feature was included in later models after 93
