Taking the rear deck out - how do I do it?
The subject should speak for itself, but....
I'm trying to take the rear deck out to replace the 4" speakers...I've got my seat out as well as the thrid brake light, but it still feels like something has a firm hold on it. I don't want to jus yank it out b/c I'm afraid I'll either break something or won't be able to get it back in. Any thought/questions/comments/SUGGESTIONS???? Thanks.... and before you hyperventilate and tell me to "Do a search next time", I did search. Came up with nothing, cept this and it doesn't help much:
https://www.clublexus.com/forums/sho...r+deck+removal
That confused me; what's he talking about? Gimme a shout and help me out!
Originally posted by henrynguyen
Well on my 93 sc400, I took off the whole cover. There are two black plug screws located at the center of each back seat. Pull them out first. Then the seat belt cover for the left and right(becareful with this part, it break very easy). Take off the sub cover(very easy, you might be able to take the sub out too). Next pop off one side first, and reach your hand under the cover and try to pop them up until you reach the center. Then pop the remain side.
Good Luck,
Good Luck,
Forum Administrator
Re: Taking the rear deck out - how do I do it?
Here are a couple of useful threads I found with the words 'remove deck'
https://www.clublexus.com/forums/sho...threadid=34734
https://www.clublexus.com/forums/sho...threadid=49821 (refers back to prior)
It's easy man. Theres just some clips that are horizontal in the back along the windows and some of those plactic plugs that are vertical in the front. Then the carpet is kind of tucked under some other inside panels for the pillars, but it should just pull right out.
Good luck!
Good luck!
leostunts
08-10-05 08:29 PM
GS4Man
02-01-03 10:19 AM
