Wood Steering Wheel upgrade
Originally Posted by eskinol
That is definitely a younger and up to date look. Very clean, Awsome job.
I might try this up sometime in the future. Does the ES steering wheel come in other colors? I'm thinking black. This way when I decide to dye my interior black, it will all match up.
You can get your question answered.
Originally Posted by techsc400
Ha ha.... please read my first post on this thread...... carefully.
You can get your question answered.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Oh, I was referring to the wood.
with a lighter tan steering wheel.
maybe it's faded, i don't know. But ours matches PERFECTLY.
Looks great ! What's the story on the Mode and Reset buttons? What are they for? and do they work? I've wanted to do the radio control in the wheel trick, but haven't found a good solution. I was interested in your black wheel, but I'm worried about finding the right airbag.
I unplug it from inside, so they are not used.
I was thinking the same thing like you. I tried to connect four electrical wires to those two switches to hook them up to either readio switch or iPod control, (It will be so great). The problem is that there is no gap or some space to guide the wire from steering wheel through steering wheel column to under the instrument panel. You will understand if you take your wheel out.
There are only female plug and round yellow plastic cover that can rotate right after the steering wheel. There is no gap or space to put wires through.
If someone has an idea, let us know.
