SC300 Weight Reduction Worksheet
Old 03-21-05 | 06:39 PM
  #76
Xevuhtess7's Avatar
Xevuhtess7
that is a good point.
thanks for lookin at the trunk, i would have done it myself already but i dont have an sc3 yet in a few days though ill have it
Old 03-21-05 | 06:58 PM
  #77
DaveGS4's Avatar
DaveGS4
Forum Administrator
Guys I ran across this website for Supra part weights when looking for some info on Supra TT brake weight. Thought it might be useful for this thread, hope it isn't a dup.
http://www.suprahardtopregistry.com/...uction/car.php
Old 03-24-05 | 02:26 AM
  #78
JspecSC3's Avatar
JspecSC3
-Leather Door Panels are F-ing heavy!! Take them off.
-Leather rear and passenger seats
-Trunk spare, jack, and carpeting.
-Replacing OEM SC300 wheels with OEM Supra wheels is a good idea too. I compared the two and the supra wheels were way lighter.
Old 03-24-05 | 02:29 AM
  #79
JspecSC3's Avatar
JspecSC3
Thumbs up
Ohhh one more thing..EXHAUST done right! Covert your exhaust from Dual to Single using 2.5 to 2.75" piping all the way with no resonator and attach an HKS Titanium muffler. It is not only lighter but more powerful than single.
Old 03-26-05 | 05:52 PM
  #80
SCV8's Avatar
SCV8
Yeah, those younger-oriented hangouts aren't the best places to showoff your car.
You can brace a glass hood with a matt cor, balsa core, or fabricated/molded sections that look like the ones on the steel hood, as well as bond in pickup points for real latches.
Doors can be braced for side-impact with a steel tube added between the latch, and hinge areas. Still a lot of hassle for the gain IMO.
BTW the stock, drivers seat only weighed around 30 pounds or so if I remember, and the stock spare didn't really weigh that much either; don't you even have a bathroom scale?
Not that a reduction of a hundred pounds wouldn't help by just swapping seats and chucking the spare(it'd definately be noticeable).
Old 03-30-05 | 12:07 AM
  #81
Hermosa's Avatar
Hermosa
Pry your hand out of the bucket of KFC and drop 50 lbs
Seriously, I forgot the post url but someone was able to save over a hundred pounds by changing all the bolts in his Supra to titanium replacements. Now that is labor intensive.
Old 03-30-05 | 01:02 AM
  #82
0l33l's Avatar
0l33l
Yeh, and from what I hear, each bolt costs like $30 The drift soarer also has all titanium bolts.
Old 03-30-05 | 01:05 AM
  #83
newyorksc's Avatar
newyorksc
delete your reinforcement bars
Old 03-30-05 | 01:44 AM
  #84
SupraCoup3's Avatar
SupraCoup3
they're aluminum and don't weigh that much.
Old 03-30-05 | 01:55 AM
  #85
newyorksc's Avatar
newyorksc
wether it weighs a lot or a little, its still saving weight and makes a difference
when i took them out on my mkiv, it wasn't b/c of weight reduction, but b/c i was fitting an aftermarket bumper, nevertheless, weight saved = go faster, wether its 1 lb or 100 lb
is it worth it? i think so.. unless you crash
take a look below, i think the crash wouldn't have been as bad if the rebar was there, right?
Old 03-30-05 | 06:09 AM
  #86
VSsc400's Avatar
VSsc400
front aluminum bar = 8lbs
Old 03-30-05 | 02:31 PM
  #87
lalaland's Avatar
lalaland
if you are going to replace all the bolts to tit. might as well redo the entire body as cf (easy and cheap just time consuming) like a zonda.
Old 03-30-05 | 02:40 PM
  #88
VSsc400's Avatar
VSsc400
cf body is neither cheap nor easy.
Old 03-30-05 | 05:52 PM
  #89
soarer479's Avatar
soarer479
ok i weighed everything that i have pulled out of my car just to see what kind of weight ive lost. so far ive lost 200 lbs! heres the list its very short and basic stuff
stock seats-83lbs each
trunk carpet (the heavey one on top not the thinner piece that covers the spare)-6.5-lbs
back seats upper and lower- 25.5lbs
spare tire-52lbs
jack and all that stuff-8lbs
the new seats i put in were 24 lbs each i believe. so ive done pretty good i think with very few things
Old 03-30-05 | 06:06 PM
  #90
JspecSC3's Avatar
JspecSC3
What kind of seats did you put in?
