SCFAQ: Differences between the SC300/400 and feature changes by year
Keeper of the light
Info Provided by Rich @ http://www.intellexual.net/sc400.html
1992 Model
Introduction of Lexus SC400
SC400 4.0-liter (242 cubic inches.), four-cam, 32-valve 90° V8
Horsepower at rpm, 250 hp @ 5,600 rpm.
Torque at rpm 260 lb-ft @ 4,400 rpm.
0-60 mph acceleration 6.9 seconds.
1/4-mile acceleration 15.3 seconds.
Top track speed 150 mph.
Fuel consumption 18/22 mpg City/Highway.
Aerodynamic drag coefficient 0.32 ,0.31 with opt. rear spoiler
4-Speed automatic Electronically Controlled Transmission with intelligence (4ECT-i), with power/normal shift modes. Rear-wheel drive (optional Traction Control System).
4-wheel independent, double-wishbone suspension.
Vehicle speed-sensing, progressive power rack-and-pinion.
4-wheel ventilated, power-assisted anti-lock discs (ABS).
1992 Model
Keeper of the light
Info provided by Rich @ https://www.clublexus.com/forums/new...ewthread&f=157
Differences between the SC300 & SC400
The SC300 comes with a 3.0-liter 182 ci cast iron inline-6 motor with aluminum heads (engine designation: 2JZ-GE) and a choice between a Toyota A343E 4-speed automatic transmission with overdrive or a Toyota W58 5-speed manual transmission (available from 1992-1997).
From 1992-1997, the power was rated as 225 horsepower @ 6000 rpm and 210 ft/lb torque @ 4800 rpm. From 1998-2000, the power was rated as 225 horsepower @ 6000 rpm and 220 ft/lb torque @ 4000 rpm. Curb weight ranges from 3494 lbs. in 1992 to 3560 lbs. in 2000.
The SC400 comes with a 4.0-liter 242 ci cast aluminum V-8 motor with aluminum heads (engine designation: 1UZ-FE) and a standard equipped Toyota A343E 4-speed automatic transmission with overdrive (from 1992-1997). No manual transmission was ever offered for the SC400.
From 1992-1995, the power was rated as 250 horsepower @ 5600 rpm and 260 ft/lb torque @ 4400 rpm. From 1996-1997, the power was rated as 260 horsepower @ 5600 rpm and 270 ft/lb torque @ 4400 rpm. From 1998-2000, the power was rated as 290 horsepower @ 6000 rpm and 300 ft/lb torque @ 4000 rpm. Curb weight ranges from 3575 lbs. in 1992 to 3655 lbs. in 2000.
Manual transmissions were never offered for the SC400 and were discontinued after 1997 on the SC300. The SC300s that came with optional Toyota W58 5-speed manual transmissions do not come equipped with traction control.
In 1998 the SC400 received a Toyota A650E 5-speed automatic transmission with advanced ECT-i and a burl-wood gated shifter (from 1998-2000), while the 1998 SC300 received a Toyota A343E 4-speed automatic transmission with burl-wood gated shifter (from 1998-2000).
In 1998, both the SC300 and SC400 received VVT-i (intelligent variable valve timing) engine technology. These motors have completely redesigned heads, which boast variable valve timing on their intake camshafts via an oil-driven helical gear-drive. 1998 and newer Lexus models with 4.0L V-8s are capable of low to high 14-second quarter miles. - (info provided by gs400998)
The SC400 came stock with 16x7.5-inch alloy wheels and the SC300 came stock with 15x6.5-inch turbine-cut alloy wheels.
The SC400 came with power automated telescoping/tilting steering wheel, and the third brake light was mounted inside the spoiler as opposed to on the rear dash behind the windshield in the SC300. The SC400 has larger disc brakes (11.7-inch front & 12.1-inch rear) compared to the SC300 (10.8-inch front & 11.4-inch rear). The SC300 had an optional but very rare velour (gray or tan) interior and optional but very rare hard top (no moonroof).
There are no substantial body differences between the SC300 and SC400. Models that did not include a spoiler with LED-third brake light, standard on the SC400 and optional on the SC300, were fitted with a third brake light on the rear deck behind the rear windshield.
ACCELERATION
Year, Model, & Drivetrain 0 - 60 mph Quarter mile
1992 SC300 4-speed auto 7.2 sec 15.8 sec at 89 mph
1992 SC300 5-speed manual 6.8 sec 15.4 sec at 90 mph
1993 SC400 4-speed auto 6.9 sec 15.3 sec
1995 SC400 4-speed auto 6.7 sec 15.2 sec at 93 mph
1998 SC400 5-speed auto 6.3 sec 14.7 sec at 97 mph
ACCELERATION
Keeper of the light
1993 Model
Passenger airbag SRS added.
New Lexus Portable Plus Cellular Phone option.
Automatic headlamps added.
All outboard passenger seatbelts now include "ALR" function that allows easier use of a child seat (without a locking clip).
New exterior colour: Graphite Metallic.
1994 Model
Instrument panel illumination changed from white to amber.
Climate control system revised for CFC-free refrigerant.
New emissions controls and on-board diagnostics.
Revised stitching on leather-wrapped steering wheel.
Thicker steering wheel rim.
1994 Model
Keeper of the light
1995 Model
Revised front air dam; extension deleted.
Revised tail lamps.
New wheel design.
Cornering lamps replaced with foglamps.
Audible remote entry.
Revised power passenger seat.
Parking brake handle moved 0.4-inch farther away from driver's seat.
Climate control and audio system displays changed from green to amber.
Outside temperature gauge added.
Second cupholder added.
Revised audio system.
Meets 1997 side impact standards.
Slight suspension and steering retuning.
New noise-control measures added.
Ivory instrument panel changes hue.
New interior-trim colours: Black Leather replaces Gray Leather
New exterior colours: Renaissance Red, Platinum Silver Metallic and Teal Mist Metallic.
Revised tail lamps.
New wheel design.
Keeper of the light
1996 Model
Engine still is a 32-Valve V8, but power uprated to 260 hp.
Horsepower at rpm, 260 hp @ 5,300.
Torque at rpm, 270 lb-ft @ 4,500.
0 - 60 mph acceleration 6.8 seconds.
Top track speed 149 mph.
Meets 1997 federal side-impact standards.
Multifunction remote entry system with audible signal, car finder, trunk release and "panic mode".
Rear-window glass-imprinted antenna.
Pre-tensioners added to front seatbelts
Adoption of electrochromic mirrors
Moonroof adoption of one-touch open slide function.
Lexus chrome-plated wheels.
Exterior colour discontinued: Teal Mist Metallic.
Exterior colour addition: Bordeaux Pearl.
1997 Model
Flush foglamps.
New upper/lower grille.
Color-keyed side skirts.
Redesigned rear spoiler, bumper and taillamps.
New alloy wheel design.
Exterior colour discontinued: Sandstone Beige Metallic, Royal Jade Pearl and Midnight Indigo Pearl
New exterior colours: Shadow Rose Quartz, Classic Green Pearl and Royal Sapphire.
1997 Model
Flush foglamps.
Keeper of the light
1998 Model
New engine with continuously Variable Valve Timing with intelligence (VVT-i).
Horsepower at rpm, 290 hp @ 6,000.
Torque at rpm, 300 lb-ft @ 4,000.
0 - 60 mph acceleration 6.3 seconds.
1/4-mile acceleration 14.7 seconds.
Fuel consumption 19/25 mpg city/highway.
Aerodynamic drag coefficient 0.32 (0.31 with optional rear spoiler).
New five-speed Electronically Controlled Transmission with intelligence (ECT-i).
Five-speed automatic Electronically Controlled Transmission with intelligence (ECT-i).
Overdrive fifth gear, auto-select shift program, engine/transmission networking, flex-lockup torque converter
Improved tires.
Genuine wood trim on the center console.
Electronic programmable garage-door opener.
Gated shifter and wood- and leather-trimmed shift ****.
Adoption of in-key multifunction remote.
Vehicle theft-deterrent and immobilizer system, with in-key transponder.
New exterior colors: Imperial Jade Mica and Baroque Red Metallic
1999 Model
Automatic Sound Levelizer (ASL).
Adoption of Digital Sound Processor.
Six-disc CD auto-changer standardized.
Floor mats standardized.
Three-spoke steering-wheel design.
Daytime running lights.
Larger brake size.
SC 400 V8 engine meets Transitional Low-Emission Vehicle (T-LEV) certification for 50 states.
New exterior colors: Golden Pearl, Millennium Silver Metallic and Angora Beige Metallic.
2000 Model
On-board Refueling Vapor Recovery (ORVR) system.
Exterior colour discontinued: Baroque Red Metallic.
Exterior colour addition: Cinnabar Pearl.
Improved tires.
1999 Model
Larger brake size.
2000 Model
aypues (07-22-23)
Keeper of the light
Info Provided by Rich @ http://www.intellexual.net/faq.html#001
Production year revisions in the SC300
The rear shifting assembly on the SC300 was changed in 1995 and is the same as the Supra NA (as far as I know '93-98), but it is unknown if the '93-94 Supra NA uses the same transmission because the TRD quick shift kit is designed for '94.1 and later. The transmission change went along with the changes that were made to the transmission tunnel. The 1995 transmission is longer and taller so you can cut the existing hole where the shifter goes through but you will have to hammer part of the tunnel to make it taller. Basically the '92-94 SC300s have the same W58 manual transmission, but then the '95-97 have an updated version. Original info: provided by SDSC300
dahozzman
SC- 1st Gen (1992-2000)
12-29-03 07:44 PM
