Some Carbon Fiber fun. (Part1)
Well, now that im done with school and all, I just basically do nothing all day except find a job. So I decided to cover the wood trim up in carbon fiber. My friend has a big roll of it so I figure we'll make some use it. Here are some pics of it so far.
The wood we started working on today... (center and driver door pieces)
Passenger side piece that we did on monday
A close up shot
The other piece on the passenger side
Waiting to dry to I can sand and clear coat it
Ready to wrap
All laid out, ready to cut
Wrapped with some fresh resin on it..
More pics to come... I still have to sand down the pieces when they dry and spray some clear coat on them....
A close up shot
Ready to wrap
are you just using one layer of CF? not in bad way...i'm sure it's enough for trim pieces.
are you letting them sit outside to dry, or are you vacum bagging them?
looks good. I hope they turn out okay.
Originally Posted by TWISTED II
won't there be fitment problems if you wrap the stock pieces when you try putting them back?
Honestly, I doubt there will be any problems. Someone on here has done it before and it fit fine. One little layer of CF and some resin shouldnt take up that much room but we'll see. I might actually get the passenger door pieces back in sometime this weekend since we did those on monday.
Matt- that will be coming soon. As you can tell I have alot of time on my hands so I plan on doing whatever is brown, black. Eventually.
Originally Posted by ACleanSC4
interesting carbon fiber weave...
hope you don' thave any problems on the edges, you'll probably be able to sand it out, but the CF tends to harden out flat....
I used vacuum bagging to make these...pure cf...no wrap
I used surfboard resin , its easy to work with and had UV protection in it. for cheap carbon fiber goto www.CARB.com
How do you get that part off of the car? Specifically the one that sits in front of the passenger above the glovebox? It APPEARS from my limited looking that there is a nut that you can't really get to unless you rip the whole dash apart. Its that the case?
Mike
Mike
Mike
Mike
