SC- 1st Gen (1992-2000)
The complete headlight HOW TO clean DIY + projector refinishing
Old 10-16-05, 12:24 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
It's all good Goose
Now onto resealing. Take some 100% pure black silicone (I used ace hardware brand - $6 per tube). You will set the reflector into the face glass and run a bead of silicone around it to keep it in place.
Then you'll do the same thing to the black headlight housing. Time is of the essence here guy's..... this stuff dries fairly quick.
O. L. T. is offline
Old 10-16-05, 12:26 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Now put the two halves together and put the factory clamps back on that hold it together.
Run another bead of silicone around the outside and rub it smooth to make certain the seal is good.
O. L. T. is offline
Old 10-16-05, 12:31 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
YOU are DONE!
NOW let's look through the glass at that projector
I'll stick a air hose in there tommorrow and remove the excess lint from the towel. Now you have completed the steps to a fresh new set of headlights with clean projectors. Enjoy your new found cut off line in your headlights and extra bright output!
Side note: once you are assembled, there are two tubes on the back that help vent the assembly. check to see if there is a filter stuck in there in each tube and if not until you can get a sponge and cut it up, just stick some cotton in there to act as a filter.
O. L. T. is offline
Old 10-16-05, 12:36 AM
nnnickkk
nnnickkk's Avatar
so doing this next weekend....
nnnickkk is offline
Old 10-16-05, 12:40 AM
boobstar
boobstar's Avatar
A little off topic but the piece below. Is that the actual bulb or is the bulb seated in that. The clear part on the end of mine is melted or something from what I can see outside of the headlights.
boobstar is offline
Old 10-16-05, 12:45 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
That's just a cover. Odd looking one too. Everything on this dang car from the city light cover to the shifter looks like a...............
O. L. T. is offline
Old 10-16-05, 12:47 AM
MongooseGA
MongooseGA's Avatar
What did you use to reseal the pieces?
Thanks for the write up. I cleaned the exterior of my lights today. Sanded and polished. I was going to post pics, but they all came out blurry
MongooseGA is offline
Old 10-16-05, 12:49 AM
boobstar
boobstar's Avatar
So if that cover is melted or whatever. How can I replace it? Or should I just cut that part off???
boobstar is offline
Old 10-16-05, 12:51 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I wanted to take advantage of having a DSLR Digital Rebel to do as many DIY's as I can so we can begin to have good pics with each DIY we have.
On a side note, This may be one of the few cars that do not depend on the chrome headlight housing to produce light. Once it comes out the projector it fires directly into the lens and the only thing the chrome seems to effect is the intensity of the city light's ability to light the housing. SOOOOOOOO if you wanna paint the chrome black, go right ahead.
O. L. T. is offline
O. L. T.
Keeper of the light
O. L. T.'s Avatar
well you see how it pops out. I guess just be creative.
O. L. T. is offline
Old 10-16-05, 12:54 AM
MongooseGA
MongooseGA's Avatar
I wanted to take advantage of having an DSLR Digital Rebel to do as many DIY's as I can so we can begin to have good pics with each DIY we have.
Having a good camera handy is always a good idea. My parents just bought some insanely powerful digital with a million MegaPixels, and I got the old 2.8MP. It's not a bad camera, I just can't take pics.
Old 10-16-05, 02:42 AM
NPSC303
NPSC303's Avatar
BWHAHAHAHAHA
NPSC303 is offline
Old 10-16-05, 04:25 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Nice write up B! I'm still chicken to chuck my headlights into the oven though lol
Must do it soon.
Jose
BLK13X is offline
Old 10-16-05, 06:31 AM
np20412
np20412's Avatar
Holy good writeup batman Nice Job OLT
Can someone tell me what grit sandpaper to use to sand down the vertical lines in the headlights? Also is there anything else that is involved with sanding down those lines other than just using sandpaper? If I open the headlights to clean my projector (which looks a lot like OLT's did, even though my headlights are barely a year and half old) I want to do the sanding all at once, rather than reopen them later.
np20412 is online now
Old 10-16-05, 06:37 AM
plex
1UZFE/2JZGTE
plex's Avatar
Wow that was a nice write up. would you be willing to do this for a fee for others? im just a lazy bastard that's all.
plex is offline
Quick Reply: The complete headlight HOW TO clean DIY + projector refinishing
