Gas pump keeps shutting off
I'm completely stumped. I picked up a '95 SC300 the other day and on the long drive home everytime I go to fill up the gas pump shuts off after only a few tenth's of a gallon. I can eventually fill up but this is a super PITA.
This happens on every pump I've been to and no matter how much or how little I push the handle the flow will cut off after a few seconds. Anyone have any experience with this kind of problem or have any suggestions?
next time you fill up try holding back the plastic cover on the nozzle. it could be your filler neck spout is bent and causing the nozzle to think you're tank is already full.
I had this problem for the entire 6 months I owned my SC. It was a huge PITA! The only way it wouldn't do this for me is if I lightly held the gas handel and did it slow, otherwise it would shut off very often.
Thats funny because I have this problem not on my sc300, but on a 98 Accord. Still haven't figured it out and yes it is more annoying than anything. Someone said to check if the filler pipe is pinched which should be on the passenger side wheel well for the sc300. Although I have not checked it on the Accord yet.
I've tried all sorts of crazy angles trying to get it to not shut off. I had asked the previous owner about it but he said that never happened for him, maybe I just don't have the magic touch.
that happens to me occasionally, i found that putting the nozzle only partially in the hole takes care of the problem.....just enought so the gas doesn't go all over the place
this just happened to me when i was with my friend earlier tonight in her hyundai accent...
we were trying to pump gas and it would stop every 3 seconds... it was sooooooooooooooo damn annoying and she says it does this all the time.
it took us like 20 mins just to get about 8 gallons.
i tried half way in, moving the nozzle around in different positions, lightly pumping it... nothing... it just stops like 100 times when filling up.
next time you're trying to pump gas, when opening the gas cap, turn it slowly. This happened on my LX and the dealer said to turn it slowly to release the vapors of the gas. Then you should be on your merry way and paying too much for gas.
