SC- 1st Gen (1992-2000)
Water seeping through carpet in front passenger seat??
Old 09-30-08, 03:58 PM
romeo291
romeo291's Avatar
Default Water seeping through carpet in front passenger seat??
This is really weird, but whenever it rains, I noticed that water is seeping through the carpet on the front passenger side. Nowhere else on the carpet is wet except this spot. Before I start tearing my carpet apart to figure out the cause of this, do you guys have any ideas as to what is causing this?
Old 10-01-08, 07:17 AM
RolxuSC400
RolxuSC400's Avatar
This is a very common issue and discussed a number of times on here. Most of the time its associated with the sunroof drains being clogged, especially if after rain or one of the parts of the HVAC unit is clogged, i forget which part or tube, search its out there.
Old 10-01-08, 03:03 PM
TURBO819
TURBO819's Avatar
Default Under Chassis
I would jack the car up and look under neat. There are some black plug in the under chassis. It might be worth a quick look.
Old 10-01-08, 03:39 PM
andrewwake
andrewwake's Avatar
Also, if you have taken off your door panels and the plugs didn't go back in properly, this could be letting in water, happened to me on my drivers side.
Old 10-01-08, 06:30 PM
1985zcar
1985zcar's Avatar
Most likely sunroof drains. Clean them out with a small flathead or pick.
Typically those drain plugs in the floor are sealed in and can't really just fall out.
Old 10-01-08, 09:45 PM
romeo291
romeo291's Avatar
Thanx a bunch for the information guys!
blkvader
09-13-21 08:05 AM
AdillyWay
IS - 1st Gen (2001-2005)
01-12-14 05:20 AM
starstreak
03-10-11 08:22 PM
mydawgz
08-03-10 07:11 AM
dumdumgreg
01-14-06 09:36 PM
Quick Reply: Water seeping through carpet in front passenger seat??
