Brake lights wont work....need help
After spending a good amount of time trying to search here if anyone had the same problem. i ended up finding nothing. basically my brake lights dont work. everything else works though. if i turn on my lights my tail lights everything works fine(including the dual filament bulbs for my brake lights). however when i step on the brake the 2nd filament doesn't light up. i have checked the bulbs and they all work fine. also checked fuses in engine bay. havent checked fuses in the drivers side kick panel though. any suggestions on what the problem might be?
that might be it. since i also have to push the shift lock button to disengage it from park. if this works you're my hero!!!! btw how do i replace it?
i got another sc400 i can grab parts from.
Get a meter on the wires right at the brake light and have someone step on the brakes. test for voltage and test for cont. to groun. you could have a wire grounding out as well.
i have a parts with a working brake switch and i swapped it out already but still doesnt work..... anymore suggestion guys? its getting really bad for me here since people downtown like to ride my *** when im driving and i had a few close calls when they cant see that im already braking.
i already checked the fuses in the engine bay. call me dumb but ive been trying to find the one on the driver side foot well. where exactly is it located or is there something i need to do to take out the whole fuse box?
thanks guys. i really hope that its the fuse. i dont really want to bring it to my mechanic when it turns out to be something easy to fix. will figure out if that is the problem tomorrow.
