Is this the Radio Wiring Harness I need to install a Headunit?
I have a 1998 SC300 and am putting in a head unit on Monday.
This is the head unit i'll be installing...
http://www.crutchfield.com/p_158GT64...w&rvm=ShowAllt
now..Is this the Wiring harness i'll need?
http://www.amazon.com/gp/product/B00...ef=oss_product
if you did a search on the forums you'd find that there is no aftermarket wiring harness available for the sc300/sc400. its been asked so many times. you have to hard wire the headunit in.
to save you some time. heres the wiring diagram you'd need. http://www.intellexual.net/faq/lexusstereo.swf
Well I just installed a stereo with the Metra 70-8112 amp intigration wiring harness direct fit to vehicle female socket "A" with original amp. everything besides the sub works (installing new sub amp and subwoofer.
The Metra Metra 70-1761 comes with 2 wire harness, the larger wire harness is a direct fit to Socket D for the sub. you get both of this and there is no need to cut your oem wire harness which should never be cut, if there is an alternative.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
