SC- 1st Gen (1992-2000)
Want to change my citylight bulbs
Old 10-22-10, 08:46 PM
boostinsc
boostinsc's Avatar
Wink Want to change my citylight bulbs
My low beams are bluish and the stock city light bulb is stock , just my opinion it don't look good. So i want to change the bulb to a different color maybe amber or like the bightest white/blue. Can you guys show me some pics of your city light/on setup suggestions/pics on how it would look pls......btw i cant change it just by opening the hood because it a pain am thinking i have to take the headlight out i don't know
Old 10-22-10, 09:00 PM
chnk
chnk's Avatar
removing the headlight will give you more room to pull out the bulb
just buy some white leds, i got mine from a local hid store for like $5
Old 10-22-10, 11:04 PM
turbodremz
turbodremz's Avatar
search...there are a few threads showing a couple different setups. No you dont have to remove the headlights, but it does make it easier.
IIRC you want an led with a T10 base. But search, and you will find the exact bulb size, how to remove your headlights, and find a custom city light projector mod...
Old 10-22-10, 11:35 PM
scENFORCER
scENFORCER's Avatar
I bought white bulbs for it but after a few written explanations I still can't figure out for the life of me to change them out lol. Guess I'll be taking out the entire headlight..
Old 10-23-10, 12:05 AM
turbodremz
turbodremz's Avatar
I can take pictures of my headlights in a few hours and show how to change the city lights.
Old 10-23-10, 10:19 AM
turbodremz
turbodremz's Avatar
Default City lights bulb change DIY quickie
Ok guys here it is. I would have shown how to remove the headlight step by step, but to make things short, there are 2 10mm nuts behind the headlight in the fender, simply pull back the front upper section of the fender lining and wedge your hands in there and you will feel them, and then there is 1 10mm bolt holding the headlight in at the top under the hood (my tab is borken). Once you remove the headlight, the city light is easy to get to:
You can see the bolt inserts on the left side of the headlight where the 2 10mm nuts would be at.
Recessed inside is the city light just to the left of the LB bulb, on the passenger side, it will be on the right of course.
Turn it counter-clockwise to remove it, and simply pull it out.
remove old bulb, replace with T10 wedge base of your choice. As for modding the city light housing, thats up to you, I left mine stock and have no issues.
Hope this helps, sorry for the shaky pictures, I havent had my coffee yet. Also I know there might be some variations between the headlights depending on the year, these came off my 92 SC300.
Old 10-23-10, 01:23 PM
scENFORCER
scENFORCER's Avatar
Awsome. This is just what I needed, I can probably do it without taking off the headlight now..
Old 10-23-10, 01:46 PM
boostinsc
boostinsc's Avatar
^post some pics when you do
Old 10-23-10, 04:58 PM
Black_SC
Black_SC's Avatar
i have the predator mod available on my headlights haha...but i dont have it hooked up...
Old 10-23-10, 10:58 PM
chnk
chnk's Avatar
love the red but i get so much cop attention with my sc it be a bad idea
Old 11-05-10, 08:12 PM
SC1984
SC1984's Avatar
I just swapped out my city lights for some white led ones. The passenger side was a breeze. The drivers side, instead of taking off the headlight, I just disconnected the battery and moved it out of the way. Use needle nose pliers to take out the connector, not alot of wiggle room. Heres some before and after pics with just the city lights on.
Attached Thumbnails Want to change my citylight bulbs-1.jpg   Want to change my citylight bulbs-2.jpg   Want to change my citylight bulbs-3.jpg   Want to change my citylight bulbs-4.jpg
Old 11-05-10, 08:19 PM
TexasSC300
TexasSC300's Avatar
SC1984, why does the 2nd photo passenger light look blue then the 3rd photo it looks white?
Old 11-05-10, 08:21 PM
SC1984
SC1984's Avatar
Yea I dont know why it did that. Could of been the angle I was holding my phone. But the light is really white in person
Old 11-05-10, 10:51 PM
boostinsc
boostinsc's Avatar
still haven't done this as yet. now i need to change my sidemarker bulbs
Old 11-06-10, 12:34 AM
Kyle1JZ
Registered User
Kyle1JZ's Avatar
i have LEDs in mine but Ive one through 3 bulbs for some reason the bulb will just start flickering. I dont really know why it happens. Confuses me
Quick Reply: Want to change my citylight bulbs
