Replace your fuel filter without loosing fuel*
Old 07-09-11, 09:28 PM
sc4doubleO
sc4doubleO's Avatar
Default Replace your fuel filter without loosing fuel*
I hate working with fuel. The smell and the chemical burns are no fun. *Let me start by mentioning that you will loose the fuel in the line but no fuel from the tank will be lost using this method.
Lets start with the tools needed.
Place a piece of regular rubber hose on the tips of your needle nose pliers. I used some fuel rubber hose I had laying around.
The rubber hose tips are to protect the hose here is an example.
There are two fuel lines just above the right rear axle. Crimp the rubber portion of the feed line. This will not damage the line if it did I wouldn't be doing it.
Use your crescent wrench and flare wrench to remove fuel filter fittings. Gas in the line is present and will squirt out. Let it drain out and continue to remove the filter.
No fuel leaking. If fuel still leaks that means you must tighten your pliers a bit more.
All is left to do is install your new filter with absolutely no rush and discomfort. Don't forget to remove the pliers.
The following 2 users liked this post by sc4doubleO:
Boergy (08-09-18), java300hp (08-11-18)
Old 07-09-11, 10:47 PM
scviolence
scviolence's Avatar
great diy good job
Old 07-09-11, 11:23 PM
aka paco
aka paco's Avatar
nice, i definetly should have done something like that when i did one on my last SC.. lol it was a mess..
Old 07-10-11, 12:12 PM
mr/griffin
mr/griffin's Avatar
why do you have to remove the pliers? they look so comfy
over40driv
over40driv's Avatar
This is excactly what these forums are for. Thanks
Old 07-10-11, 04:57 PM
Sinistr
Sinistr's Avatar
Niiice. This should help out more than a few people on here. Thanks for posting that up. Good job!
Old 07-10-11, 05:36 PM
jadu
live.love.laugh.lexus
jadu's Avatar
great write up... i gotta do this myself..
Old 07-10-11, 06:10 PM
RyanV
RyanV's Avatar
I just changed mine today as well.
Wear chemical resistant gloves(they sell a new brand at autozone for $6, they are red)
start the car and then disconnect the big power connector on top of the fuel tank in the trunk, the car will die and so will the line pressure.
You will still drip gas this way, but should be minimal.
You could also use the method above, crimp the line, not a bad idea!
EDIT: It's also eaiser if you bend the filter bracket out of the way as well. You can bend it right back and hold it shut using pliers while you thread the bolt back in....just another tip
Ryan
Old 07-10-11, 07:00 PM
SH_JZZ30
SH_JZZ30's Avatar
Also removing the gas tank cap helps.
Old 07-11-11, 04:05 AM
aka paco
aka paco's Avatar
I found disconnecting fuel pump and starting the car to relieve pressure and removing the gas cap made little to no difference in gas pouring out of the fuel line when i did it.
i had about a 1/8th of a tank of gas, I think personally crimping the fuel line like above is probably the smartest least messy way to go about it.
Old 07-11-11, 09:39 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
This is a great write up! I might have to give this a shot some time.
Old 07-11-11, 01:00 PM
Luv2xl
Luv2xl's Avatar
try this on a North eastern car and let me know if it still works this way.. lol
Great writeup.. but I just pray that removal of my filter is as cake as yours was..
Old 07-11-11, 04:09 PM
sc4doubleO
sc4doubleO's Avatar
If your fittings are slightly rounded or badly rusted I would advice you leave it alone. Chances of making it worse are high. You can always cut the metal lines and add aftermarket fittings but its a hassle.
Old 07-11-11, 04:21 PM
sc4doubleO
sc4doubleO's Avatar
I also did not see any difference by removing the gas cap and fuel pump connector while engine was running. The issue is gravity since the tank sits so high.
Old 07-11-11, 07:41 PM
ISFFUN
ISFFUN's Avatar
If you have the tools to do it even if it means cutting the lines by all means do it. My filter from my 1997 w/ 130K was coffee black/ grimy.
Quick Reply: Replace your fuel filter without loosing fuel*
