SC- 1st Gen (1992-2000)
SC300 D2S MINI retrofit
Old 08-18-11, 08:54 AM
Tabaka
Tabaka's Avatar
Originally Posted by uras300
Totally, and those guys that are swapping 1JZ and 2JZ GTE in when they already have 2JZ GE have too much time on their hands as well. I mean, they have to pull the engine out, upgrade associated components, and it's just not worth the time.
Please educate yourself on art of retrofitting. Your eyes will open, and (with retrofitted projector on your SC,) you will see what the buzz is about.
Honestly, I get a little what you are saying. Life is short and you should enjoy doing anything that makes you happy. If you feel like spending $3,000 for a 300hp engine to push a 4,000lbs car around that's great. If you feel like spending $3,000 on a 10 day vacation in Hawaii, fantastic. I'm not personally attacking the OP. I'm sure there is a benefit if you need to upgrade your lighting. It's your time and money, do what you want.
Old 08-18-11, 09:00 AM
1J0Z SC
1J0Z SC's Avatar
Looks great man! I love the red!
Old 08-18-11, 09:28 AM
97-SC300
97-SC300's Avatar
Who was complaining about retrofits again?
Nice job buddy. Retrofits (tsx, s2k, etc.) are a million times better than the stock projectors.
Old 08-18-11, 09:32 AM
MattStarr
MattStarr's Avatar
Ok, this is weird, I was just about to post up my retrofit that used the same method, same projectors (Morimoto mini H1's) and even my car is the same color, except I used shrouds and didnt have to hack my cosmetic inserts. That's just too weird
P.S. I'm aware that my bondoed lip is destroyed, my cousin decided to take my car rally racing when I let him borrow it
Old 08-18-11, 09:50 AM
cmh
cmh's Avatar
^^^damn that looks good... i think imma paint my headlights black... i keep seeing this and i think i like it.
Old 08-18-11, 10:24 AM
blacksc4
blacksc4's Avatar
very nicely done, whered u pick up the MINIs? i was looking into doing this but im also thinking a whole different setup
@cmh ^^ deff do it, black on black headlights are the best, and gives u the chances to clean ur lights and projectors while waiting for paint to dry
Old 08-18-11, 10:38 AM
abounly
abounly's Avatar
At first i thought retros were a waste of money. I would not personally ever buy a set. But i was lucky enough to win a set off TRS.
I got FX-R's and when i tested them out holy crap. They go far and continue to have their cut off line be sharp
Old 08-18-11, 08:12 PM
lilSCsteve
lilSCsteve's Avatar
Man, that turned out nice!
Old 08-19-11, 10:20 AM
01gs3
01gs3's Avatar
Thanks everyone for the comments whether positive or negative.
sc300jz, I chose mini's over tsx because the mini's are bi-xenon. For some reason, the exposed projector doesn't bother me. I think it looks kind of cool. I'll see if I can get side pictures to show you how it looks. And btw, the FX-R is DEFINITELY too large to go into our housings. I have an extra set of FX-R 2.0 and 1.0 that i tried to squeeze in there, and the bowl is just too large.
mattstar, great minds think a-like. Since you have h1's, your projector should be smaller than the d2s I used. I guess that's why I had to start destroying my bezel. Looks great, good job.
I did a retrofit because it benefits my driving habits. I drive all times of day and night. My s2000 has such a wide field of vision, I thought why not my SC? People buy plug and play HID kits all the time, I'm just doing it the proper way so other people won't be blinded. Plus, it only cost me about 150 and a few hours of my time.
blacksc4, if you're looking for MINI's, I have some extra sets from friends that fell through. https://www.clublexus.com/forums/2ge...rojectors.html
and to anybody that cares, here's a link to my GS retrofit, and a friends IS retrofit.
https://www.clublexus.com/forums/gs-...xperience.html
https://www.clublexus.com/forums/is-...-retrofit.html
Old 08-19-11, 07:33 PM
broda805
broda805's Avatar
did this my sc few months ago and love it
Old 08-19-11, 10:24 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
bixenons eh? how did you get to fit the motor in?
Old 08-20-11, 06:09 AM
01gs3
01gs3's Avatar
Kaydee, the projectors already had the solenoid inside. So no extra work besides tapping into the high beam wires for power/ground.
Old 10-31-11, 04:51 PM
DriftSC
DriftSC's Avatar
*snip
I wish I would have read this before ordering my FX-R projectors, but since I had them, I had to make them fit. After a ton of trimming to the projector, I managed to get them in there and centered in the factory shroud. It was a total pain, but it is do-able. My next set will be minis though :P
Old 07-17-12, 05:32 PM
lLOlRlElN
lLOlRlElN's Avatar
hate to bring this back from the dead. but I just made some observations about OPs pictures and Mattstar;s pictures and some other pictures i found comparing the two projectors (d2s and h1).
according to this image, the projectors are only millimeters in difference.
and what I've noticed is that MAttstar removed alot more material from the back housing than the OP did to offset the depth of the mounting position.
this leads me to believe if you remove the same amount of material from the back housing as Mattstar, then the D2S projector will fit without cutting the chrome housing and exposing the sides of the projector such as OPs end result.
Old 07-17-12, 06:49 PM
eknine9
eknine9's Avatar
Any more pictures of this sexy cutoff?
Quick Reply: SC300 D2S MINI retrofit
