SC- 1st Gen (1992-2000)
Tach Mod for Swaps/ Coil-on-plug Setups - R109
Old 10-03-11, 11:20 AM
HiPSI
HiPSI's Avatar
Default Tach Mod for Swaps/ Coil-on-plug Setups - R109
Can you guys clarify that this is the correct resistor that I need to add a wire to?
After pulling the cluster out:
This is the only r109 resistor that I see, is this correct?
I know that the Supra this resistor is actually on the back of the tach itself, but it looks like it's on the main board on the back of the whole circuit on the sc300?
Do I just solder in a wire on each end to bypass the resistor?
Thanks!
Old 10-03-11, 12:15 PM
kinch09
kinch09's Avatar
https://www.clublexus.com/forums/per...ach-issue.html
here this might help ill be doing this soon and saved it awhile back
Old 10-03-11, 12:55 PM
HiPSI
HiPSI's Avatar
That did the trick! Good as new.
Old 10-05-11, 12:00 PM
kinch09
kinch09's Avatar
cool
Deegee
03-03-16 09:49 AM
AnthonyGS3
11-13-12 10:46 PM
ReganSC300
08-02-12 01:51 PM
KevinLS400
08-13-08 07:03 AM
Quick Reply: Tach Mod for Swaps/ Coil-on-plug Setups - R109
