Passenger door won't open from inside or outside
I don't know where you get $700. the windshields are 229.95... I've replaced glass in an AMG Mercedes and it wasn't even half that. I just called a place locally and it's 159.99 installed either side but a few days wait cuz they don't have them in stock they even offered me a 5% discount because of the wait. even ebay has the drivers side for 59.95 and the passenger for 75.89. I have plenty of window adhesive and window tint but still would have to wait for shipping but I still don't see the problem here..
Thanks for all the suggestions cl, What I end up doing was rolling the window down and remove the rubber trim between the glass and the door. After removing the trim, I could see the bar that attaches to the door handle. I used a coat hanger and pressed down on the bar while opening the interior handle.
hello I am new to the forum, i have a 95 lexus sc 300, i was able to purchase both tail lights and harness to change my tail lights the lights came off of a 94 lexus sc 400 but i cannot get the parking lighs to come on, and i cannot pass the brake and light inspection to drive my car do i need to have that years lights in order for them to work, turn signal, ER lights, everything but the parking lights come on.
Hi,
I have a ES 330 - 2005 - Lots of Miles!!!!: )
Still runs strong, but I have a locked passenger door.
The actuator or locking mech has a rapid "clicking" noise when I try to Unlock the door with the key fob and the unlock on the door itself.
Tries:
#1 - Door is closed and cannot remove paneling??? Don't know how to get to the door's interior parts.
#2 - Can barely see when window is down and trying to pry open the door between window and see what I can see. ( I have not tried to use any coat hanger or jimmy stick)
#3 - I have called 5 locksmiths in my area and nobody can find a way or won't even come out to see if they can open it.
Any suggestions? Any help or additions to what I have tried. Please let me know.
Thanks.
Tries:
Thanks.
Sounds to me like you might have broken the handle "arm" that goes from the exterior handle, down to the latch assembly, inside the door. If that was the case, then you might need an exterior handle latch clip that holds the arm in place. A $5.88 part at most Lexus dealerships.
Anyone know the part number for that actuator arm clip????? I need that....
See if this helps..... Hard to tell which part matches yours...
http://www.lexussouthatlantaparts.co...roduct=5797922
Dougg62
01-01-12 02:24 PM
dogwisper
SC- 1st Gen (1992-2000)
16
11-18-11 04:04 PM
