Lost Lock
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Someone broke into your car and screwed around with things.
Your insurance rather than the warranty should pay for this mess.
Apply Occam's razor.*
* A principal which holds that when more than one solution to a problem exists, the simplest and most obvious answer is likely to be the most valid. In other words, never seek a complicated explanation when a simple one is available.
yeah i agree someone tried to break into your car
have you noticed anything missing
where from in nj
but if this wasnt a theft attempt
then that is really weird
this happen to anyone else
where from in nj
Nobody tried to break in.
The lock cylinder assembly and trim around it is held in by a screw from behind (the door panel has to come off to access it). It kind of acts like a set screw. This came loose and detached itself from the cylinder. I guarantee you the lock cylinder is floating around the floor of the carwash right now or in the sewer. If you still had the lock assembly, you would see the threads on the back for the set screw and if you look at your door you will see the tip of a gold screw recessed in the rubber trim (rightmost edge).
The morons should have used a little locktite.
Your looking at about $340 for the parts, installation, and to have a locksmith rekey the new cylinder. Been there, done this.
-Roger
-Roger
Roger,
Thank you for your reply. The dealership removed the driver's side panel to reduce the base vibration from the stereo and probably didf not reattach the panel appropriately causing the lock to be lost. Now the question is will they be willing to accept responsability and pay for the repair?
Roger,
Thank you for your reply. The dealership removed the driver's side panel to reduce the base vibration from the stereo and probably didf not reattach the panel appropriately causing the lock to be lost. Now the question is will they be willing to accept responsability and pay for the repair?![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
It may have been a break-in attempt. I had this happen to me. They drilled out the lock without damaging the handle or door. To replace the lock is expensive. They need to cut a temporary key to fit the new lock. In Canada there is only one person that has the codes to do this. It also takes an hour of shop time to r+r the door.
![Red face](https://www.clublexus.com/forums/images/icons/icon11.gif)
By finding out what happened to my lock, I was able to pitch a fit at the dealership and they will cover the parts & labor to replace my lost lock. Thanks to Club Lexus members for their imput
Robert
Robert
>Apply Occam's Razor<
In this case, Lockam's Razor?
Refreshing to see someone here (who else, but) referring to Occam's Razor (the Law of Parsimony).
I had a friend whose concept of Occam's Razor was to always assign unexplained events to extraterrestrials. Simple enough.
