TSB actions after warranty expires
So I have 63,000 miles on my 2002 SC430 and have been reading the TSB that replaces the rear bushings. I went over to Lexus of Portland yesterday to talk to them about getting my bushings replaced. They told me that it was only a warranty issue and since my car is past the factory bumper-to-bumper warranty it was not applicable.
Anyone know the truth on this?
Technically, they are correct.
However, many dealers will perform the work as a "goodwill" gesture even if your car is out of warranty. Really depends on how helpful the dealership wants to be. Are there any other dealerships nearby? You other option is to call Lexus customer service and see if they can help. They are usually try their best to keep the customer happy. Good luck.
This TSB came out, as I recall, within the first 12 months of the car's introduction (which was in April '01, I think). Shortly thereafter, the new bushings were put on all newly made cars. As I recall, the deal was that if you asked the dealer for them for them or made a non-specific complaint about harsh bumps, the dealer would make the change per the TSB. I had it done, and it made a little difference, but it's not a big deal.
Since they had to keep the car overnight and pull out the whole back end to do the job, it wasn't something they wanted to to for every car, since it was not safety related, was fairly labor intensive, and offered only a slight improvement in ride quality. I doubt that a dealer would want to go that far on a car that's out of warranty. Since the owner had no problems with the ride for over 4 years during the first 60,000 miles, I doubt that he would notice the difference.
If your car was made in late '02 or in 2003, you probably have the newer type bushings, but I do not know how to tell for sure, other than to check the posts on this board and see when that TSB was issued. That was about the same time, obviously, that they made the change in the factory.
Thanks,
I have a 2003, but I could not really find the details of the TSB on the Forum, so I thought someone may know. The only real clunk I have is the roof clunk when closed when going over driveway curbs and what not so I think there is no bushing issue with my car.
Thanks,
RMR
Thanks,
RMR
If I'm not mistaken, the first bushing replacement was also problematic and a second replacement became available. I was a little too quick to have mine replaced so I have the first replacement set. I've heard that awful *clunk* only twice, both after having hit a serious bump.
Technical Service Bulletin Titles for 2002 Lexus SC 430
TSB Number & Issue Date TSB Title
EG007-05 MAR 05 Cooling System - Radiator Cap Inspection Procedure
BO002-05 FEB 05 Audio System - Door Replacement Procedure
BO001-05 FEB 05 Audio/Interior - Audio Door Hard to Open/Close
TC002R-03 DEC 04 Engine Controls - ECM Memory Reset After A/T Service
AC005-04 DEC 04 A/C - Sensor Inspection Procedures
EG013-04 NOV 04 Engine - Rough Idle While Stationary in DRIVE
BO011-04 NOV 04 Navigation System - Door Replacement
BO006-04 SEP 04 A/C - Control Panel Base Sub-Assembly Replacement
EL004-04 JUL 04 Electrical - Trunk Release Intermittently Inoperative
NV003-04 APR 04 Interior - Inside Rear View Mirror Loose/Vibrates
NV002-04 APR 04 Body - Door Wood Trim Panel Vibration
EG003-04 MAR 04 Engine - Drive Belt Chirping/Squealing Noises
SS002-03 DEC 03 Engine Controls - O2 Sensor Monitor Threshold Values
BO012-03 DEC 03 Interior - Seat Belt Extender Applications/Availability
SS003R-01 SEP 03 Engine Controls - ECU Programming Error Displayed
SS001R-01 SEP 03 Engine Controls - ECU Programming Procedure
BO007-03 SEP 03 Interior - Trim Panel Removel/Installation Precautions
NV005-03 MAY 03 Body - Convertible Top Ticking/Rattling Noises
EG001-03 FEB 03 Exhaust System - Sulfur Smell
SS005R-01 JAN 03 Diagnostic Tester - Immobilizer Function
EL011-02 DEC 02 A/T - Vehicle Won't Shift Out of PARK Intermittently
PG012-02 OCT 02 Suspension - Ball Joint Inspection Method
BO005-02 SEP 02 Interior - Seat Belt Extender Availability/Applications
EL010-02 AUG 02 Navigation System - Identification Method/DVD Map Data
PG006-02 JUL 02 Tires (Run-Flat Type) - Repair Evaluation Criteria
TC001-02 MAY 02 A/T - Fluid Requirements
EL004-02 APR 02 Antenna Mast - Service Manual Supplement
PG005-02 APR 02 Tires - Inflation Pressure Adjustment
AU002-02 APR 02 Audio - No Sound From Amplifier
BO002-02 MAR 02 Tonneau Cover - Retractor Bracket Addition
PG004-02 MAR 02 Engine Cooling - New Pink Coolant
EL003-02 MAR 02 Air Bag Wiring Diagram - Manual Update
SS001-02 MAR 02 Drive Shaft - Tool: Nut Chisel
AU001-02 FEB 02 Audio System Amplifier - Installation Cautions
EG002-02 FEB 02 OBD II - Readiness Monitor Drive Patterns
EL001-02 JAN 02 Alternator - Fuse Application
PG002-02 JAN 02 Certification Label - Replacement Availability
PG001-02 JAN 02 Corrections Index - Repair Manual
SU003-02 JAN 02 Front Stabilizer Bar - Abnormal Noise on Turns/Bumps
SU001-02 JAN 02 Rear Suspension Member - Noisy
SU002-02 JAN 02 Stabilizer Bar - Torque Revision
PG003-02 JAN 02 VIN Plate - Replacement Availability
EL008-01 DEC 01 Electrical Wiring Diagram - Amended
SS011-01 DEC 01 Airbag Deployment Wire - Sub Harness
BO001R-01 NOV 01 Seat Belts - Extender Availability Update
ST004-01 NOV 01 Steering/Tires - Vehicle Pull/Manual Supplement
SU004-01 NOV 01 Rear Suspension Member - Noise
BO013-01 OCT 01 Cup Holder (Instrument Panel) - Available Separately
AU001-01 OCT 01 Audio Sound System - Inoperative/Erratic
BO012-01 SEP 01 Upper Console Panel - Installation Precaution
ST002-01 SEP 01 Steering Wheel - Off Center Adjustment Procedure
EL005-01 AUG 01 Door Lock Remote Transmitters - Programming
BO008-01 AUG 01 Retractible Roof - Operation Cancels
SS004-01 JUN 01 Diagnostic Tester - `Customize Feature'
PG018-01 MAY 01 Tires - Precaution When Adjusting Pressure
PG014-01 APR 01 Spare Tire - Storage Kit Installation
PG013-01 APR 01 Tires - Dismounting With Pressure Warning Sensors
SU002-01 MAR 01 Wheels (18 inch) - Balance Adjustment Procedure
PG010-01 MAR 01 Compass - Initial Calibration During PDS
PG006-01 FEB 01 Tire Pressure Sensing Transmitter - Activating Procedure
PG002-01 JAN 01 Rear License Plate - Installation
Technical Service Bulletin Titles for 2003 Lexus SC 430
BO009-04 SEP 04 Restraint System - Seat Belt Extender Availability
EL006-03 JUN 03 Navigation System - Map Screen is Blank
AX001-03 MAY 03 Cellular Phone - Buzzing Noise in 'Hands Free Mode'
Jackalope
11-29-08 11:06 PM
jrj102
01-09-08 01:48 PM
