Brakes....Clunk/Grinding/clicking/ticking noise when slowing to a stop/turning?
I need front pads at 48k miles. is this about right?
The dealer said 3mm left that was 1k miles ago.
Have a friend that can install. Went to buy on line
today and found 6 different sets at:
http://www2.lexpartsonline.com/parts...Set&category=N
Don't know what to get.
Advice please.
Thanks
Advice please.
Thanks
48,000 miles on front brake pads I think is great. Just get the same EXACT ones you have, "Genuine Lexus Parts".
IMO, I believe those online may be "oem ", not "Genuine Lexus". Cheaper ones will usually produce more dust, more noise, less braking, less miles or even wear longer ... but abrasive on rotors.
Sensei
Sensei
Nasty Rattle D to R or R to D?
Wonder if you have the nasty brake noise (like a clanking sound) after the first stop from revrese to drive or drive to reverse.
I notice it appears to get worse as the pads wear, has anyone been able to quiet it down? It just sounds crappy. In my SC400, I expereinced the same thing, but never looked into any way of making it less annoying...just changed the pads, but they had boo-koo life left. Seems like an expensive way to remedy this issue.
Anybody figure a way yet? People give you a funny look when it happens.
NICE430
NICE430
Yes, of course... as bt430 has suggested. When changing pads you should always re-surface the rotors or replace them if needed.
The "Lexus Genuine Parts" are available thru Lexus/Toyota dealerships... It's only a good price when you get the right parts. Carson Toyota seems to be reputable...
RMR- There 's usually "V" or "W"shaped wire springs on top of the pads. You'll notice a small hole on the edge of brake pads, this is where one end of the spring goes. The other side pushes against the inside of the caliper. This tension keeps the pads off the rotors and eliminates the symptoms you have. Other things to consider, missing end clips or shims can cause pads to rattles loosely. Lexus pads usually come with new shims, there should be 2 on the back of each pad...
Sensei
Sensei
Sensei
Sensei
my dealership they dont. 25 extra for shim kit
Thanks for the tip Sensei,
I found these at Carson's L-TunedParts web site
http://www.l-tunedparts.com/product/?id=508
Have any of ya'll used these?
Clinking sound when turning during parking?
Hi everyone,
I just bought a used '03 SC 430 with 28K miles on it. The car looks and drives great, but it seems everytime I'm at slow speeds parking, when I turn the steering wheel, I hear this metallic clink sound from near the front axel.
The car doesn't seem to do it while I'm turning at higher speeds while driving, just mostly during parking. I'm planning to send the car into the Lexus dealer for a 30K service soon anyway to have this checked out, but I was wondering if any other SC 430 owners experience this out there?
Thanks for any info.
Tony, he said from the front. CV joints are present only on the rear on our car, and those rarely fail. Front axle CV joints are prone to fail on FWD and AWD cars, but with way more miles than he has.
My guess is crash damage. Did you get a carfax on your car? Or maybe P/O hit a deep pothole and never checked the car.
I'd attempt to get it checked under warranty, and see what happens. Just tell them not to perform any work out of warranty if not authorized by you first. Good luck man.
Welcome to CL and congrats on your very first post.
It could be a variety of things and since the car is not in front of me:
All Lexus's have an issue with strange noises from the front end, especially when parking due to the design of the braking system. Pads wear, hardware wear which creates a ,"loose" braking system and allows movement which translates to clicking sounds or clunking sounds. Very common when backing up and then going forward during parking. It could also be the brake shield-the large steel round shield behind the brake rotor but that would be more of a continual rubbing sound.
or
Could be the tire is rubbing on something while turning
or
Could be a rock ,nail, or screw is in the tire which will give a clicking sound while rotating.
Those are common causes of clicks on these cars. Many other possibilities exist as well.
Again, welcome aboard.
Lee
or
or
Lee
Wow,
Thanks for all the informative answers. I guess this clinking sound isn't too common with the rest of the owners.
Good call to remind me to tell Lexus service to not do any out of warranty work.
The CARFAX record was clean for the vehicle, so I hope it's not due to prior collision damage.
Thanks again for all the great answers! I really enjoy the car!
