Airbag Light on Dash
We just received the car today and I have been getting an intermittent airbag light on the dash. I dont know if its coincidence but if it seems like when i move the driver seat back and forth is what sets the air bag light to turn on and off..
example:
i adjust seat all the way back to my liking.. turn off car.. turn back on and airbag light is on..
i adjust seat again turn car off.. turn back on.. light is gone..
strange..... If i hook up a reader to pull codes then does it tell me what airbag its throwing the code for?
example:
Does your seat memory work? ie. does it beep if you press the "set" button together with memory 1 or 2 (while the key is in the ON position, park, and foot off the break pedal).
If you seat memory doesn't work I think you just hear the beep because the seat needs to be re-calibrated. Not sure why you see the airbag light though!
(btw. you can recalibrate the seats by moving them first totally backward and then totally forward)
^^That's it. Makes sense.
Here you go....seat wiring & component diagrams. Position S26-LH. You should disconnect the negative terminal on the battery before working with the wiring components, wouldn't want you to detonate a squib and inflate an airbag.
What about Bob? Oh yeah, what are we going to do without Bob!
