LED Conversion Project
#76
No state inspections or emissIons check in Florida. Buy a beater, drive it off the lot and away you go.
I installed my LED DRL's knowing I would lose my high beams. I very seldom drive the car at night so that was a risk I was willing to take.........like running my spacers.
Got that right, we ride our rides with all its best attributes and so-so stuff. End of the day, happy to drive them.
#77
Is there a list somewhere of all the led bulbs one would need to do a total conversion? I tried the vendor listed in this posting, and could not find a good listing.
thanks,
thanks,
#79
Just installed my step lights and trunk lights, all 168 LED's. Looking good. What a whole lot difference.
#81
What do you mean, switch the wires? I ordered through iJDMtoy a week ago and they are sending me the BA9 bulb for the dome. The guaranteed me that it would work after i sent them photos b'c I informed them it was not DE3175 as they had in their manuals.
#83
Good luck - note I tried three different dc9's.
#84
Hi. I have a 2004 so it might not be the same as yours (i didn't read to look for the year of your sc). The bulb fits but doesn't turn on - the pole are reversed compared to the socket. See the cooment for the 168's ... Says to simply plug it in the other way ... Can't do that for the dc9's. I took off the dome light mounting base and the wires are soldered - easy enough to switch them but I didn't do it yet. Would be a lot cheaper than the flat panel you can get with adaptors.
#85
The lights look sharp Mandy.
#86
Well I was going to get the flat panel, but iJDM told me this DC9 would work. Guess they just wanted to make the sale. When you do get around to taking off the lighting base for the swap, if you could take a few photos and some instructions, please? I feel like I'm going to have to undertake the same adventure. I would really appreciate it. Thanks.
#87
The flat panel worked for me in my dome - and it would only light up after I reversed the polarity by connecting red wire to black wire and black wire to red wire. The flat panel I bought from eBay had the base separated from the actual panel and i had to plug the panel wires into the base wires. That is how you can "swap the wires" - plug them in the opposite way from the wire color codes. The much brighter light is well worth the effort. You should try it.
#88
From what I can tell Mandy, you are certainly up to the task!
#90
Well just like last Sunday, pollen count was so high and it was cruddy weather in ATL, I was looking at my engine bay and there's nothing to clean, so the bulb lit up...use the plugs that have been collecting dust and the rest was history.
I will tackle the Fogs soon. The LED fogs are collecting dust as well.
