SC300 cluster reworked and perfect F/S
Keeper of the light
This unit has 157k on it, fresh #24 bulbs for backlight and i have two sets of needles built, choose which you want between blue or white.
This unit can be purchased either with the black face shroud for $235 or without for $200
Fit's the AUTO SC300 BUT will work in an sc400 however the tachometer will not read correctly if used in the 400 (it will read low).
Shipping = $10 First come, First serve. Only one unit available.
FYI - You can have odometers rolled back, legally too. If you're in 408, there's a place called Palo Alto Speedometer in Palo Alto that can roll this one back to your actual vehicle miles.
well I'll save the $ 130.00 to spend on mine then.if I can't change tacs.
thanx for the insight.should I PM you for the details.?
re;payment options..
