FS: SC300/SC400 Big Brake Setup (LS400 Calipers used)
FS: SC300/SC400 Big Brake Setup (used 4 piston calipers - similar to the supra tt upgrade)
Fully loaded with pads, shims, pins.
$210 local
$240 shipped
Buy with confidence: https://www.clublexus.com/forums/sho...hreadid=119137
You can get more info on this setup and results from here:
https://www.clublexus.com/forums/sho...hreadid=120615
Here is a pic of onehotsc400's calipers which have caliper stickers and are painted:
Calipers unpainted:
$210 local
$240 shipped
Calipers unpainted:
Originally posted by aasc300
I really want this setup, would you be intested in any trades?
Looks like I'm stuck with the twin-piston (although big) stock calipers for a few years longer.
Just one quick question, I was told large wheels are needed, like even bigger than 18s... if these came stock on the mid 90s LS400s, and those have only 15" or 16" wheels, how come they wont fit on an SC400 with 16" wheels?
The "high-disc" I believe is referring to the offset of the wheel. With 2 pistons on each side of the caliper and the hub still retaining the same center line in relation to the mounting point of the rim to the hub, the back side of the rim would have to sit farther away from the hub (offset). Any one correct me if I'm wrong.
I have a stock airbox, struts, springs, brake lines and muffler s for a 1992 sc300, a set of pcw 5 spoke wheels with rain tires, and a daizen rear bushing set (new in box). Any of that sound interesting?
My computer at home is down , but I will try. They are pcw 5 star wheels with Michelin rain tires (I think). The wheels are ugly, but not damaged. Tires are good 80% or so tread left. The tires are worth the money, the rims are basically just coming with the tires.
Forum Administrator
Originally posted by aliga
SOLD to jawnthen!
SOLD to jawnthen!
aliga
SC400 / 300 Classifieds
17
11-17-04 07:09 AM
aliga
21
07-27-04 02:21 PM
aliga
07-09-04 06:36 AM
