NA-T tubular header
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Performance Factory long tube split design (3-2-1) turbo header with DP, Turbonetics Racegate, and W/G recirculation pipe. All Swain coated. Asking $1745 shipped.
More info:
http://supraforums.com/forum/showthr...hreadid=247254
Thanks,
Mike
slasher48@***.net
More info:
Thanks,
Mike
slasher48@***.net
Hey I have a couple questions for you.
1. Is it avalible with a 4" DP?
2. Can you get only the manifold? If so how much?
3. What is the manifold made of (304 or 321) and what are the tube dimensions, including gauge?
4. What are the availble flanges for the turbine inlet?
qtb33,
1. The DP is 3". I'd recommend making one with parts from ATP-Turbo if you need 4".
http://www.atpturbo.com/Merchant2/me...egory_Code=STL
2. This is a personal kit.. Not sure if these are still made as Performance Factory's website is gone. Only selling as a kit w/ the manifold, DP, wastegate, and WG recirc pipe.
3. It's made of 304SS. Not sure of the other specs, but will try to find out.
4. T04 tang undivided. Also compatible w/ divided turbos like Greddy T78/88, etc.
Thanks,
Mike
Thanks,
Mike
suprakidxx
Performance & Maintenance
05-05-15 11:58 AM
