FS: 2JZ-GTE setup - US spec
Sorry if this is in the wrong section. I've got this posted over at the SF, but figured some of you SC300 guys may be interested in this.
I've got a complete 35K GTE motor for sale. I have a pic of the compression test results if anyone is interested. Motor has US turbos, 550cc US injectors. It was a JDM unit that was converted over to US spec, since I didn't want to mess with trying to get the MAP thing to work. That, and the ceramic bladed turbos can't boost as high as the steel US versions. Asking 3100 for the motor
I also have a 6spd ODB1 US ECU for the above motor, MAF and US 6spd supra harness. Not sure if the harness will fit the SC or not, someone chime in on that.
200 for the ECU, 65 for the maf and 450 for the harness. I'll make a package deal to anyone looking to do a full GTE swap in their SC for everything.
please email me at madmaxx@charter.net
James
James
Original buyer has flaked for the motor/ecu/harness combo. Offer up everything I have for 3800$, before I end up just tucking this back in my garage for a while.
Send me a PM on the SF (MadMaxx) or email me at madmaxx@charter.net
Thanks!
James
Thanks!
James
Originally Posted by BigManne
i am interested. check your SF pm's. does this motor have the us tt cams also?
Originally Posted by mteele
do you still have the MAP sensor and the 440cc injectors?
Yes I do, I'm guessing you're a 1JZ guy? Send me a PM over at the SF or mail me. I have a bunch of 1JZ stuff as well.
You wouldn't happen to have a stock 1J fuel rail would you?
James
The 1JZ I have has side-feed injectors like the 2JZ (??). As far as I ever knew, the 1JZ weren't top fed in any stock configuration, and I don't have any aftermarket rails.
James
James
