1JZGTE TRD "Stage 3" clutch kit, used, cheep! from 7MGTE MKIII Supra, So. Cali
Got a "Stage 3" TRD clutch that will work for anyone with a 1JZGTE swap. Its from a MKIII 7MGTE setup. It has less then 5000 miles on it. The Disc has plenty of meat left. The PP side of the disc has a similar design to the stock clutch and looks almost new. The flywheel side has kevlar pads to take on years of use. The PP is a high clamp unit and you can still see and feel the machine groves on the PP surface as if it were new. asking $215 + shipping. Comes with pressure plate, disc and bearing. Item is in Hemet, So. Cali 92544, for local pick up trdracing.com has this clutch listed for $461.12
![](https://www.clublexus.com/gallery/data/500/1J_TRD_CLUTCH_0002.jpg)
![](https://www.clublexus.com/gallery/data/500/1J_TRD_CLUTCH_0004.jpg)
![](https://www.clublexus.com/gallery/data/500/1J_TRD_CLUTCH_0006.jpg)
![](https://www.clublexus.com/gallery/data/500/1J_TRD_CLUTCH_0005.jpg)
![](https://www.clublexus.com/gallery/data/500/1J_TRD_CLUTCH_0013.jpg)
turbodremz
SC- 1st Gen (1992-2000)
12-02-10 02:12 PM
