FS: 440cc injectors & 2JZ MAP sensor (1JZ upgrade)
This setup is a direct plug & play for the 1JZ-GTE. The 440cc injectors are the correct imp. and are the side feed. They are from a JDM Supra 2JZ-GTE along with the MAP sensor (important, the Aristo sensor is different). By installing the new sensor with the injectors, no tuning is needed to add the bigger injectors. Besides doing this, it also increases the boost/fuel cut by about 5psi. And you know what that means
Asking $315 shipped. These sets are becoming harder to find, so jump on it!
Originally Posted by happypanda
if this will work with my na-t set up..i can pick it up...let me know
