Swift Racing Torque Converter
Guest
Posts: n/a
What forms of payment do you accept?
I assume that this is in perfect working order, is it?
About how much did it cost to get your TC installed?
Questions are just a formality, I will probably be bidding on it soon
"The converter has a 2,500 rpm stall" -from ebay description.
A few more questions, does the 2,500 rpm stall mean that while at a stoplight the rpm gauge is at 2,500? It just seems that 2,500 rpm is pretty high at a standstill. Does the TC effect gas mileage much? Ok, that's it
Guest
Posts: n/a
It is in perfect working order. I don't recall exactly how much it was to install, but it wasn't bad. I accept paypal, cashiers check, money order, personal check or whatever. The stall is actually 3,000. I had a misprint in ebay. The car will still go at a lower rpm. The main difference is when you hold down on the break as hard as you can you can get the rpm's up to 3,000 before the tires spin, that means you can take off really hard and there is more torque multiplication as well. As far as gas milege goes I would say about 1 or 2 miles per gallon.
