Injectors 550cc injectors with fuel rail
Old 10-14-01, 03:09 PM
Dohc3l
Dohc3l's Avatar
Default Injectors 550cc injectors with fuel rail
I'm upgrading my fuel system for my SC300, I'm selling (6) 550cc injectors and a supra fuel rail with it. I'm asking 450.
Dohc3l is offline
Old 10-14-01, 08:06 PM
Ebanks
Ebanks's Avatar
Default hey
I'll sell you my <5k mile old 785cc injectors from my SC300 to replace them
-Ethan
Ebanks is offline
Old 10-14-01, 08:14 PM
Dohc3l
Dohc3l's Avatar
I'm actually going to go with the greddy 720 since they make a vpc chip for the 720, why did you use the 785cc? That's a weird size for injectors.
Dohc3l is offline
Old 10-16-01, 12:06 PM
Ebanks
Ebanks's Avatar
I am running stand alone, so I can really run whatever size injectors I need. The injectors are actually rated at 75 lbs/hr which is right around 785cc.... 720cc would have been a bit small for my needs (would have worked, but I would not have been happy with the duty cycle I would have been seeing).
-Ethan
Ebanks is offline
Old 10-23-01, 08:24 AM
SC300TURBO
SC300TURBO's Avatar
dohc...what car do you have...720 wont work on a n/a sc300.....there too big...will only work on a supra tt.....Jeff
SC300TURBO is offline
Old 10-30-01, 12:40 PM
Dohc3l
Dohc3l's Avatar
jeff,
i have a sc300 turboed .....and the 550cc's are not supplying enough fuel
Dohc3l is offline
Old 11-01-01, 10:41 PM
Ebanks
Ebanks's Avatar
Jeff- Are you saying they won't work in general on an SC300, or just not with the VPC?
-Ethan
Ebanks is offline
Old 11-02-01, 06:44 AM
SC300TURBO
SC300TURBO's Avatar
sorry about that ethan...i should clarify....720s wont work on a VPC with the sc300...will work with stand alone...Jeff
Old 11-08-01, 11:15 AM
CmputerWiz
CmputerWiz's Avatar
Default Re: Injectors 550cc injectors with fuel rail
So these are injectors for the SC300 engine, NOT the Supra? The two cars use different impedence injectors...
SR
CmputerWiz is offline
Old 11-08-01, 11:57 AM
Dohc3l
Dohc3l's Avatar
yeah, but you can use the injectors by putting on resistors
Dohc3l is offline
Old 11-08-01, 04:38 PM
CmputerWiz
CmputerWiz's Avatar
What size resistors? That would seem like a sorta hack job tho. If these are STOCK supra injectors...they WON'T fit the SC. They just don't fit on our cars...but you can get aftermarket supra injectors that will fit.
SR
Old 11-08-01, 09:58 PM
Dohc3l
Dohc3l's Avatar
they do fit....in my sc.....i'm running it.....infact it's still on there, i'm just waiting to get my fuel system in, to take it off
Dohc3l is offline
Old 11-09-01, 06:03 AM
CmputerWiz
CmputerWiz's Avatar
Do they not fit into the SC's fuel rail? I talked to my SC guru, and he said the 550's won't fir the SC sizewise. But I didn't ask exactly why...
SR
That-Guy
SC400 / 300 Classifieds
10-26-08 11:35 AM
HakanUras
Performance & Maintenance
04-06-03 10:30 AM
Quick Reply: Injectors 550cc injectors with fuel rail
