FS: NA brakes (sc300) + w58 5 speed swap
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
upgrade time again
1) Complete brake system from a 1995 Lexus SC300 5 speed manual transmission with 97,000 mileage. $600 obo
All brake parts are original from the car(except pads) and function perfectly. Rotors have been freshly resurfaced and aftermarket pads have ~50% life remaining. The following is included:
4 rotors (front and rear)
4 loaded brake calipers with pads & hardware (front and rear)
Dust shields
and brake lines if anyone wants them
2) 5 speed manual transmission from same 1995 Lexus SC300 car. $1,100 OBO
Complete assembled w58 transmission including shifter + linkage (shifts smooth). You can just put this entire trans package (with flywheel) and go..no break-in needed. It's complete Plug and Play!
Slave cylinder assembly
OEM Throw Out and Pilot Bushing (1,200 mileage on them w/ new clutch = new)
Flywheel
RPS Max Pressure Plate and RPS 6-puck sprung disc
--> this clutch setup has exactly 1,200 mileage on it.
--> clutch was installed properly = no squeaks or any annoying noises
--> clutch was properly broken in = MUCH easier to press pedal compared to new and clutch engages like butter, not harsh. Daily driver friendly AND holds more power than typical full face clutch discs
Dust shields
Flywheel
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
bump
my replacement upgraded transmission is here, so I have no use for w58 manual transmission package. It will just be sitting in the garage until it goes to a good home.
![Over Here](https://www.clublexus.com/forums/images/smilies/overhere.gif)
