FS: SDS EM-4 Engine Management System
i bought this from a member on SF.com (don't remember who) but its a user-programmable ems. Its used but in good condition, i'm asking $850+shipping for it.
Main site is here www.sdsefi.com
Everything included:
ECU
LCD programmer
Air temp sensor
Water temp sensor
2JZ-GTE Main wiring harness
Injector harness\
Fuel trim control, +, - 50%
Comprehensive manual
Crank sensor (E,F)
Coil/amp unit (F)
Extra Info:
Adjustable Parameters
RPM - every 250
Manifold pressure - 64 locations
Water temperature - 32 locations
Start function - 33 adjustments
Acceleration - 3 adjustments
Closed loop - 5 adjustments
Boost limiting
Rev limiting
Ignition timing - every 250 (E,F)
MAP retard - 64 locations (E,F)
Knock control (optional on E,F)
RPM switch - every 250 (optional)
Nitrous ignition retard (E, F)
Fast idle temp cutoff - 32 locations (optional)
Data logging AFRs vs. RPM
Extra Cost and Optional Items From SDS
MAP sensors (1,2 and 3 Bar)
CHT sensor
Knock sensors
Oxygen sensors (1 and 4 wire)
Fuel pump relays
Fast idle solenoids
Injectors
Fuel pumps
LED mixture meters
RPM switch
TPS
Electric fan switch relays
Supercharger switch relays
Air conditioning solenoids
15,000 rpm software
Backlit LCD programmer
ECU
LCD programmer
Air temp sensor
Water temp sensor
Injector harness\
Crank sensor (E,F)
Coil/amp unit (F)
Extra Info:
RPM - every 250
Boost limiting
Rev limiting
CHT sensor
Knock sensors
Fuel pump relays
Fast idle solenoids
Injectors
Fuel pumps
LED mixture meters
RPM switch
TPS
15,000 rpm software
cartmill
SC400 / 300 Classifieds
06-30-10 10:46 AM
shaodome
11-09-09 05:57 PM
