2JZGTE Single 71mm getrag 6 speed, cams, etc etc.
Decided to sell off everything so the motor goes.
It's a 2JZGTE with the front sump pan for gs300s, cressidas, etc. (can easily be swapped for a mid sump pan for you sc300/400 guys.
The motor is complete and compression and leak down was done before we tore it down and replaced every single gasket with factory parts.
The head has Brian Crower 272 cams,
BC titanium springs and retainers,
new valve stem seals,
OEM timing belt,
ARP head bolts,
brand new water pump
brand new oil pump
Single manifold that has been braced and coated
4" ceramic coated down pipe
HKS 50mm wastegate with dump tube
20 diff wastegate springs
Precision 71GTQ turbo (billet wheel), Darin over at Titan just went 9.59 on this turbo with stock cams, stock suspension and stock motor.
4" intake with K&N
all new oil feed and return lines
precision 1000CC injectors
Billet fuel rail with all new -6 fittings and lines
Polished v. covers, intake manifold, water neck and TB
Modified stock Throttle body with traction control butterfly removed and BOV welded on
HKS SSQV
unorthodox alt pulley...woo
Brand new in the box Getrag 6 speed tranny. MSRP alone is $5600
$100 Titanium ARC shift ****
OEM 6 speed flywheel
6 speed driveshaft ends to make your custom driveshaft.
Stock auto aristo ecu
igniter
gs430 rear end with 3.266 gearing to match the getrag
clutch pedal, master cylinder, slave, shorter brake pedal, etc.
etc etc.
![](https://www.clublexus.com/gallery/data/500/medium/polished_wheelsetc_018.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/polished_wheelsetc_020.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/polished_wheelsetc_021.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/polished_wheelsetc_022.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/polished_wheelsetc_028.jpg)
![](https://www.clublexus.com/gallery/data/500/medium/polished_wheelsetc_027.jpg)
$10,500
OEM timing belt,
ARP head bolts,
brand new oil pump
4" intake with K&N
HKS SSQV
igniter
etc etc.
$10,500
same one that was reworked and braced (but not the braced one they sell on ebay) This one was coated and held 690rwhp no problem. Most people don't trust it since it sells on ebay, but since I payed 1800 on my last manifold that was known to hold up, it cracked. SO I spent a lot less on this one that hasn't cracked and that has been known in the supra community to hold up just fine once braced.
I just didn't see a point in spending 2500 on a full race manifold (even though they do look sexy)
DETUNED
18
03-31-07 01:48 PM
DETUNED
02-16-07 08:24 PM
