FS SUPRA TT 3.76 LSD REAR (Complete pumpkin)
Location: Sideways on the Yellow Brick Road! < Thats KS!
This is a 97 Supra LSD Complete Pumpkin with the coveted 3.76 gearing. Also already has the SC input yoke installed so it is a 100% bolt in. It has about 45000 original miles, just had new rear lube put in about 3000 miles ago. I may have to drain it to ship it. It’s in KS, local pick up preferred. $1000
Hey Scott, sorry we didn't get to deal on the Intercooler, turbo and sway bars a while back. However, I want to buy your pumpkin
To make sure, it is a direct bolt on for a 1992 5 Speed, right? If so, let me know where to send the money and what it will cost to ship to 85369, also possibly the weight of the Pumpkin.
I edited because I know it will go to a local seller first, consider me your first shipped dibs. I'd rather you get to just load it on a truck and wave good bye rather than carry it to a UPS store
should be a direct bolt in to the 92 5 speed, the only thing I would question is gearing. I could knock your speedometer off a bit. I will research the gears for you.
Here is a gear ratio chart, looks like the gears would change from a 4.08 to the 3.76, not bad, I know this is the rear end that everyone wants.
92-97 SC300
6 cyl, AT (4.27 ratio)
6 cyl, MT (4.08 ratio)
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
w/o turbo; (4.27 ratio) Limited Slip
w/turbo, MT (3.133 ratio) Limited Slip
w/turbo, AT (3.769 ratio) Limited Slip
97-98 MKIV Supra
w/o turbo; (4.08 ratio) Limited Slip
92-97 SC300
98-00 SC300
92-97 SC400
8 cyl (3.92 ratio)
98-00 SC400
8 cyl (3.266 ratio)
92-96 MKIV Supra
97-98 MKIV Supra
kilawatts
13
10-20-07 08:47 AM
