Cluster Conversion Service (97-99)
01-25-08, 07:22 PM
Former Sponsor
$400 for the conversion.
You will get a 97-99 cluster, and wiring harness modified to plug into your sc.
You will need to send us your dash wiring harness once you receive the cluster and modified harness.
Please specify year and make of car so we can modify the appropriate harness.
This is what a 99 cluster looks like, note we only have 2 x 99 sc300 clusters in stock.
edit: after the modification is done you will be able to plug in your older cluster as well, for car inspection, etc. basically the harness will have plugs for the new and old cluster.
note: all functions on the cluster will work, except for the outside temperature reading
01-25-08, 07:50 PM
I'm so in on this one...good find Gazi! Now if I can only get a harness for my folding/vibrating mirrors
01-25-08, 08:19 PM
Do all the functions work (temp, etc...) when used on the older models?
01-25-08, 09:11 PM
Freaking Tony I thought you called last mod already when you did the spoiler, or was it the rear seats? lol
01-25-08, 11:36 PM
vibrating mirror? what do you DO with your car man?? lol
01-26-08, 01:48 AM
Can you adapt JDM clusters to work on USDM's with 1jz setups? OBD1 if it matters... (aka. i dont know jack)
01-26-08, 05:03 AM
Former Sponsor
Quote:
Originally Posted by
RCThrine
sorry, we arent in japan.
01-26-08, 10:46 AM
Former Sponsor
sc300max
everything except outside temp
01-26-08, 08:00 PM
01-26-08, 08:55 PM
wow what about the sc4 guys? I know a SC3 cluster will work, but the rpm's will be off.
01-27-08, 06:53 AM
Former Sponsor
ihiryu
i have a 97 sc400 cluster as well, one left.
01-27-08, 06:53 AM
Former Sponsor
phrozen
wtb 5spd version =/
good luck, wont happen. 97 5 speeds are rare, install a auto and you will be fine
01-27-08, 07:42 AM
aliga
Gazi,
Just to better inform some people. The 97 will not have the gated look on the cluster, only the 98+ will.
Jonny
01-27-08, 10:30 AM
Former Sponsor
Quote:
Gazi,
Jonny
absolutely correct.
01-27-08, 05:40 PM
Gazi would it be a feasible idea to get the outside temp display to display the temp from another source, say water temp?
