FS: Gated Shifter -- plug and play
Selling my gated shifter but without the bezel and ECT switch. Someone stole them also the Nav. ![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Gated shifter comes with:
--Shifter assembly, complete wiring, with harness that goes into pre-98s. (I will label the wires where to plug it, will also help to install )
--RX400h shift ****.
--Modified SC400 shift linkage ( I don't know if this will fit SC300, but the gated shifter itself will fit both SC4 and SC3 )
--4 bolts to attach the gated shifter into the chassis.
Overdrive (O/D) button is wired, it will disengage if you shift to "4"
Your indicator lights on your pre-97 cluster will light up too.
P
R
N
4-D ........shift to "4" and you'll have O/D .
2-L
^^^ All gears are working to accommodate the non gated shifter.
Asking price is $280 plus shipping.
Again, the gated shifter does not have the bezel and ECT switch.
P
R
N
2-L
![](http://i235.photobucket.com/albums/ee42/enyce18/inter2.jpg?t=1207673283)
