FS: 2jz-GE Engine and Transmission
So i got an Engine swap on my car and i have the stock GE engine that came out of my 1st gen GS for sale, and the transmission.
The engine had a little over 200,000 miles on it, it wont really run too good. it may be a vacuum leak, or could be a bad sensor. Not sure, all i know is when it was in the car, i attempted to clean the throttle body and when i put everything back together it would idle high, stutter and die unless i gave it gas.
Use the engine for spare parts, for scrap metal, for whatever haha i just need it gone. Or fix it and use it, it was a VERY good engine, still ran very strong, had spark plugs changed maybe 3 days before it was takin out. had no problems up until i messed with it.
Transmission had same amount of miles i believe, but it works good. didnt shift hard or miss shift. as you know both these engines and transmission are very strong and durable.
Ill get some pictures up soon, and ill put alot more info about it. The engines at Execstudios ( i call it Jays shop) over here in socal, in the City of Industry.
Come pick them both up for $480.
Any questions feel free to ask, a PM will get to me faster, sometimes i forget about the threads i make haha.
Thanks!
Thanks!
Added some very crappy cell phone pictures....here you go.
Blurry i know, sorry all i have is my cell phone camera.
so once again Transmission works perfect, Engine is working but has a vacuum leak somewhere, or could be a bad MAF sensor. i didnt take the time to fix it because i was getting a new engine.
Im sure if someone takes the effort and time to fix it, it can run perfectly
EdgarLex
11-22-18 08:36 PM
pruietjr
10-10-16 06:05 PM
