2jzge and A340 part out
This motor has 50k on it, the trans has 82k. Anything you want from the motor post an offer price and ill most likely take it. I just need this thing gone! EVERYTHING IS ON THIS THING AND WORKING EXCEPT THE HEAD GASKET HENCE THE PART OUT. The car did not overheat or anything, but i did a compression check on the motor before i pulled it and 2-3 had 90psi compression. I pulled the gasket and sure enough it was done. no coolant was found in the oil or the cylinders though. EVERYTHING ELSE IS PERFECT, ALTERNATOR IS BRAND NEW!
Thanks!
Thanks!
How much do you want for the engine assy. and would you be willing to ship it to ohio? If not i could probably pick it up. Just thought i would ask.
600 obo for the entire assembly(trans, ecu, harness, engine)
20.00 for the motor mounts (arms and rubber pieces) plus shipping, PM me.
This thing still has all the accessories on it and the Alternator is brand new.
hotrodrdc
04-07-12 04:52 PM
rwdanthony
SC400 / 300 Classifieds
07-07-09 08:00 PM
sicksupra1
02-04-08 05:55 PM
