2jz Supra SC300 GS300 GE to GTE Conversion Components
I purchased a Aristo 2jz-gte motor with only 60k on it and only used the block for myself. I have the following parts available which can be used to convert a 2jz-GE to GTE with a little mechanical know how.
JDM turbo aluminum head
-includes ceramic turbos in good shape (no cast piping), upper and lower intake manifold, throttle body, fuel rail with 440cc injectors assembled.
Aluminum valve covers x 2
Cams/ Cam gears
TT metal headgasket with only 5 miles on it, yes, 5 miles.
Uncut Complete Aristo Harness
CUSTOM bent hard oil lines going from filter boss on GE block to twin turbos (made by GRIP-INDUSTRIES.COM, good ****)
OEM Spark Plug cover with Cams Exposed
6 OEM coil packs
Misc pumps such as power steering and water pump from aristo
Basically this swap would be for someone who wants to convert their 2jz-GE motor to GTE. You will also need some misc other things such as an ignitor, GTE ecu, as well as supporting mods such as a fuel pump, etc. Know the info. Good information can be found here on CL and around the internet. SOLD for $650
Cams/ Cam gears
6 OEM coil packs
Cams/ Cam gears
6 OEM coil packs
Basically this swap would be for someone who wants to convert their 2jz-GE motor to GTE. You will also need some misc other things such as an ignitor, GTE ecu, as well as supporting mods such as a fuel pump, etc. Know the info. Good information can be found here on CL and around the internet. Asking $700 for the whole lot of parts. Located in east central florida.
Cams/ Cam gears
6 OEM coil packs
spoolxexo
SC400 / 300 Classifieds
15
07-11-13 02:22 PM
DETUNED
08-21-07 06:43 PM
