Turbonetics Turbo Kit (93-97 SC300/GS300)
Hello CL, I'm selling my turbonetics kit which would be my lost and your gain. I purchased this kit for $4,200 and I'm willing to part with it for $2,500 obo. It's a complete bolt on kit that requires no tuning. The only thing missing is the intercooler piping. For inquiries, call 305-218-0874 or PM me. Thanks.
DESCRIPTION
Turbonetics Turbo Systems are for you, whether you have a four cylinder sport compact or a V-8 muscle car, Turbonetics Turbo Systems include everything you need from fuel and ignition to piping and fittings for complete bolt-on turbo performance. Turbonetics offers complete turbo systems - from air entry to exhausting to the catalyst. The Turbonetics turbo system is a true O.E. bolt-on that does not require hacking in order to install. Pieces mount to existing factory positions and maintain all optional equipment including air conditioning. With these kits you no longer have to worry about 4 - 6 weeks of downtime to get a kit fabricated because our kits can be installed within 8 - 12 hours. In addition, you don't have to worry about inexperienced tuners experimenting with your car, because our fuel and ignition management systems come pre-programmed to maintain a consistent air/fuel ratio and timing control under all conditions. Unlike others, Turbonetics can back this up with the MoTeC or Horiba real-time five gas air/fuel meter and in-house dyno testing.
DESCRIPTION
- Turbo kit contain the following:
- Ceramic Ball Bearing Turbocharger (T3/T4 Hybrid or Custom T04E)
- Spearco Intercooler System
- Exhaust Manifold - high carbon cast-steel with ceramic coating
- Fuel / Timing Controller (electronic fuel / timing management system)
- Fuel Injectors
- Evolution Wastegate Assembly
- Raptor By Pass / Blow Off Valve Assembly
- Mandrel-bent ceramic coated Downpipe with closed-loop wastegate discharge
- Intake System with Air Filter
