LS400 BBK (calipers, rotors, pads, bolts, etc...)
I have a set of front LS400 brakes for sale...I purchased these acouple weeks ago but they will not fit behind my rims...![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
$250 firm, buyer pays shipping and paypal fees.
calipers still loaded with pads, shims, pins, etc.....alot of life left on the pads.
rotors...they dont seem very worn because there is no lip on the edge yet...
shorter LS400 caliper bolts
brake line banjo bolts
pretty much everything you need for the ls400 upgrade.
pics soon.
paypal verifed.
thanks
William
pics soon.
paypal verifed.
thanks
William
just alittle surface rust on the rotors..I can clean off before I send...they will clean themselves off once you install and brake.
I'll try to find some more pics of the pads and calipers alone.
I believe they are off a 97 LS400. unsure of miles...freshly pulled off the car that had been sitting there for less then a week. car looked well maintained until it was totalled...
![](http://teamshiftpoint.com/tspmembers/William/temp/img252.jpg)
![](http://teamshiftpoint.com/tspmembers/William/temp/img253.jpg)
the calipers look clean when they pulled them...I had used some brake parts cleaner on them to try to remove the red numbers they wrote on the side of the caliper...was planning on cleaning them up and painting them
more close up pics of the calipers and pads later tonight or tomm morning.
I'm in Houston...
EDIT: calipers flowed out clean/clear brake fluid when I pushed the pistons back...no signs of leaking from the seals.
I'm in Houston...
i have a 97 sc 300 i hear you can upgrade to ls400 calipers and rotors, but what years ls rotors and calipers can you use.you can pm me with the answer THANKS anyone in the raleigh nc area with these cars with alot of knowledge and don't mind giving advice on everything about these cars pm me i need help.THANKS
https://www.clublexus.com/forums/sho...d.php?t=266465
http://intellexual.net/faq.html
https://www.clublexus.com/forums/sho...eplace+antenna
