FS: clutch pedal, complete oem stereo, front brakes
Just looking to get rid of these things I'm not using that are taking up space.
![](http://i34.tinypic.com/igls2s.jpg)
![](http://i34.tinypic.com/egembn.jpg)
The clutch pedal package includes the clutch pedal assembly, the brake pedal assembly, and clutch master cylinder from a MKIII Supra. These can be used with modifications noted in the thread titled "How I swapped an R154 into my SC400" by member 2JZLEX. THESE ARE NOT A DIRECT BOLT IN. They can be made to work, I have personally seen them used to convert a Second gen GS. My point is, If you can't make them work, don't blame he or I. Looking for $65 shipped.
![](http://i37.tinypic.com/302ceva.jpg)
![](http://i36.tinypic.com/2uh0rye.jpg)
The OEM stereo set includes the headunit, the amplifier, the cd changer, and all associated brackets and bolts. The headunit worked great, all buttons are tight and work. It is the Pioneer set and has the Orange display. The cd changer worked, but sometimes the headunit would not recognize it. Maybe it's a common problem, my loss your gain. $60 Shipped.
![](http://i33.tinypic.com/259dg8n.jpg)
OEM calipers and OEM replacement rotors. These do not appear to cheap discount auto rotors. Taken off to install my LS400's. The set is 56lbs, so i would prefer local pick-up. $40
I will not turn down reasonable offers so PM me. Sorry about the fuzzy pics, I think my camera is dieing.
