boostlogic 3in down pipe
i have a mint condition 3 in boostlogic downpipe
the boostlogic down pipe is well crafted and comes with the flex joint to eliminate eng vibrations being fed into the cabin
i would like to sell it to get another one , the reason is when i was running on a piggyback you have to run stock o2 sensors now i am on aem and run only off aem uego wb for feedback so i want a cleaner neater look
so mine has 3 bungs into the top portion of down pipe
wibeband bung up top unobstructed ,then you have a bung for 1 o2 sensor to the left of it and for the second o2 sensor to the right of it below it and the front o2 sensor reaches it just fine and then down stream right under pass area theirs a third bung that already has the bolt in type flange ( try and find that flange you will pull your hair out)
so for those going na-t or even gte setup and running piggy back you need to have o2 sensors in stream here your chance to save money and time
price as new is 350 +plus shipping
how about 275+ shipping and you save all that extra money on the new one as well as the additional money spent getting bungs welded in ( about 40 per bung) and getting that downstream flange ( about 50 ) welded in
Cannonbear
Performance & Maintenance
04-23-08 07:38 AM
LCSC
09-23-07 09:19 AM
