My final offering 92-97 sc400 supercharger kit $2100 shipped
Not going any lower on this kit, if it doesn't sell its going back on my car!
sc400 supercharger kit ready to bolt on $2100 shipped! Will work with 92-97 sc400 Richwood m90 kit has everything even fuel rails ready to bolt on 5-6psi setup. M90 is freshly rebuilt with bearings, hard coupler and sprung snout seal. All put together and filled with oil and ready to go! Also comes with accessory pulley set that scotturnot made as well. Its all here!
All you will need to do is:
Bolt everything on
cap your egr pipe coming up the back
extend your throttle cable "cable and crimps included"
Install one range colder plugs
and your ready to go, a rising rate fuel pressure regulator is a good idea to but i didn't run one at this level of boost and wasn't leaning out.
$2100 shippedin the lower 48 states
![](https://www.clublexus.com/forums/../gallery/data/4496/cid_40125874B4A34F6496AD26483D659AAE_sgc3c03d435062.jpg)
![](https://www.clublexus.com/forums/../gallery/data/4496/cid_008D5D8D0AA447FA8FF48780B165C029_sgc3c03d435062.jpg)
![](https://www.clublexus.com/forums/../gallery/data/4496/cid_888A1B5B0D674B588A59703D72F80417_sgc3c03d435062.jpg)
Not my engine but these are the pulleys "credited to scotturnot"
Bolt everything on
I have not dyno'd this kit couldn't say for sure, but its the same as other people are running. I would say around 50hp increase at this 6psi. With more boost up to 100hp gain at the fly. which is what the m90 will top out at, By the feel it produces more torque then HP as well ...
How in the world has this not sold yet??
Fully bolt on?? The only thing needed on the side is one step colder plugs??
I see dozens of threads on "how do I add some power to my SC??".. This is the solution, its amazing its still here!
So stock injectors and ECU give enough fuel? What are some decent brands of FPR's would you recommend? Does this make the car throw any CEL's or anything? And my last question is, where do you get belts for that thing? Also, this deserves a bump, pretty good deal here. If it's still available, and I can come up with some wifey approved duckets I'm all over this.
It sold already sorry. Mods please close
