HKS Boost controller / PLX DEVICES wideband
HKS Electronic Boost controller
Old unit. Comes as shown. No manual.
$100.00 *** Price includes shipping***
- PLX Devices wideband setup-- SM-AFR with DM-5 AFR display unit. - Practically new! used for about 30 minutes to tune with $200 *** Price includes shipping***
SM-AFR
iMFD Sensor Module - Wideband O2 Air Fuel Ratio
Digital Wideband Air/Fuel Sensor
DESCRIPTION:
SM-AFR accurately measures the precise wideband air fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system.
SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware.
All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge. Works with gasoline, bio diesel, ethanol, methanol, E85, LPG, and CNG.
Standard Digital Display Module
Universal 2 1/16" (52mm) Gauge
Wideband O2 Air Fuel Ratio gauge
2 1/16" Standard Size (52mm)
0.7" (18mm) Thin
Digital Accuracy
Shows AFR in gasoline and lambda mode
Must connect to SM-AFR Module
** Mine has the black dial
SM-AFR
DESCRIPTION:
0.7" (18mm) Thin
Digital Accuracy
