Janelle Ferrero HYJAXX@AOL.COM, pm or call
757-240-7518
Norfolk, VA
Swap includes: W58 transmission from an SC300 no grinds, W58 flywheel, Spec stage 4 clutch (less than 500 miles), drive shaft, center console bezel, MK3 clutch pedal (modified to fit SC300), Clutch master and slave, clutch lines.
Doesn't come with ecu or gauge cluster however we've been running it on an auto ecu with auto gauges and everything works just fine. Reason I'm selling it: upgrading to a TH400. Not willing to part out. $800+shipping.
It came out of my friends SC with 79,000 miles on it. I put a little less than 500 miles on it then laid the car up for head work. Although it was short of 500 I'd say the clutch is basically broken in.
Here's a link to unishippers- going through them is supposedly much cheaper. I always shipped to people who work at a place with a fedex account so I just band it onto a half-sized pallet and drop it off at the terminal. You would pay for the shipping when it showed up at your work. They give discounts if you use JBSupra when you call. http://www.supraforums.com/forum/sho...d.php?t=343803.
